02-21-2011, 10:38 PM | #1 |
How can I fix this?
So, finally got the motor in. Got the fender and door panels perfect. Go to put the hood on and drivers side is PERFECT and passenger side well, a little less than perfect. I have literally spent 5 hours adjusting and readjusting everything from the hood to the fenders to the core support. I am out of ideas. Maybe I should just go hoodless.
Any Ideas?? |
02-21-2011, 11:11 PM | #2 |
Re: How can I fix this?
Not a big help but I've seen a lot of them like that.
02-21-2011, 11:16 PM | #3 |
Yea, I called around and every is telling me the core support needs to be taken higher. Must me a common issue? Still no give.
02-22-2011, 12:08 PM | #4 |
check to see if it is possible to adjust your passenger side fender.
02-22-2011, 12:27 PM | #5 |
02-22-2011, 01:04 PM | #6 |
Old Skool Club
I think we are victims of the early '90's, when Lexus started the "Relentless Pursuit of Perfection" advertising campaign. That's when they ran the ads on TV, showing the ball bearing rolling as it followed the gap, or lack of, on the surfaces of the car.
These trucks were not built with that degree of perfection, during assembly. Windshield posts and door posts existed to mount the doors. Even when the door is adjusted to perfection, the gaps will not be the same from top to bottom, or the same on one side, compared to the other. But, I understand that there are people who know how to adjust all those parts and pieces and achieve as perfect an alignment as it possible. I, for one, will be seeking the advice and expertise of one of those "gurus", when it is time to assemble mine. Lord knows I don't have it.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
02-22-2011, 12:15 PM | #7 |
you can move the pin that locks your hood down. usually when aligning you want to start with the doors move to the fenders then move to the hood.
Smoking Tires Since 1992 1969 c10 AKA SIN 1985 SSWB TRAZER (super short wheel base) |
02-22-2011, 12:25 PM | #8 |
Nothing?
02-22-2011, 01:51 PM | #9 |
Maybe split the difference from side to side? These old trucks aren't perfect, I have slotted holes and changed the clips in the past to get body panels where I wanted them. You have a ton of work in front of you if you want all the gaps perfect, its possible, but its a pain!
02-22-2011, 02:19 PM | #10 |
ITS TRUE!!! I'm a perfectionist due to the magazines and commercials of today! but oh well.
Yes, I tried to split the difference but it still looks horrid and not enough to leave. I may end up cutting the mounts to the core support a little to bring the top into the hood more. Then pushing the fender toward the cab to hold the door line. Just frustrating. If anyone has ran into this specific before please TELL ME HOW YOU FIXED IT!!!! |
02-22-2011, 02:21 PM | #11 |
Do you have a different hood or fender you could try? I replaced on door mine with a different OEM door, it wound up fitting better than the original one did. Have you tried shims? maybe one in the back? Its so dang hard to tell from a pic, I feel your aggravation.
"You can put lipstick on a pig, sure it's pretty pig, but it's still just a PIG... 71 LWB Last edited by UltraBlue71; 02-22-2011 at 02:23 PM. |
02-22-2011, 02:23 PM | #12 | |
I'll try to update some more pictures asap. |
02-22-2011, 02:26 PM | #13 |
It almost looks like the bottom of the fender needs to go up or in, is the inner fender new? Was it always like that? How is your door to fender fitment? What all have you changed from what was orginally on it?
"You can put lipstick on a pig, sure it's pretty pig, but it's still just a PIG... 71 LWB Last edited by UltraBlue71; 02-22-2011 at 02:27 PM. |
02-22-2011, 02:30 PM | #14 | |
Really seems like the top area needs to come in toward the front on that side as the hood is PERFECT on the drivers side and the doors are as well. I feel like I'm losing my mind! |
02-22-2011, 02:34 PM | #15 |
1972 K20
I would start by putting your cowl on with the gasket. That is sure to raise the rear of the hood and you may find out the rear of the fender needs to move also. Do you have the rubbers in your fenders they also hold the hood back some? I just did this on my truck and it was a lot of comprimising with all the parts but it came out well for me.
Good luck |
02-22-2011, 02:40 PM | #16 | |
No I dont have any of the rubbers on the fenders, dont think any of my trucks in these years did. |
02-22-2011, 02:37 PM | #17 |
I think you are on the right track by thinking the fender (front) needs adjusting closer to the hood, but its hard to say with just a photo to look at....Keep looking it over, you will see the solution. good luck
"I'll Procrastinate Tomorrow" quote by LEEVON 71 K10 long fleet (sons truck) new 370hp 355, sm465 np205, 3.73's 33's 70 K20 long fleet 98 G3500 work van |
02-22-2011, 02:41 PM | #18 | |
Like I was saying, next step is to bevel out the mounting bracket and try to pull that guy in closer. |
02-22-2011, 05:27 PM | #19 |
If you figure it out let me know. I got the same problem
02-22-2011, 06:17 PM | #20 |
member #16
Is your core support centered right? Looks like it needs to move to the drivers side, which should close some of the gap. Theres always the possibility of the cab not mounted square on the frame.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ Last edited by john; 02-22-2011 at 06:19 PM. |
02-22-2011, 06:51 PM | #21 |
1972 K20
I feel your frustration... been there done that! I did something similar not having my cowl in place because the hood was real close. So I aligned everything and I thought I had everything lined up real good...then I put the cowl back on with a new gasket... and I had to start over because the rear fender gap was much larger now. I taped my new gasket down and back for a while to minimize the amount of hood lift. My point is the cowl (and new gasket) raised the hood and made the fender to hood gaps change which caused me to re-adjust the hinges and just about everything else. Keep at it once you get it right you will be proud of your accomplishment!
02-27-2011, 04:07 PM | #22 |
Well nothing,
Ive moved fenders, cowl, core supprt, hood, hinges. Just about to pay someone to come down and allign the dang thing. anyone wana make a quick $50-$75?? Ill even supply the beer. |
02-28-2011, 01:38 PM | #23 |
Well nothing,
Ive moved fenders, cowl, core supprt, hood, hinges. Just about to pay someone to come down and allign the dang thing. anyone wana make a quick $50-$75?? Ill even supply the beer. After the beer you wont have to align anything, It will all look nice and straight. |
02-28-2011, 04:20 PM | #24 | |
I ended up calling my old man and hes gona come try it out for me. If he cant do it then Im going to take it down to a buddy of mine who own a body shop in Chico. (were not buddies enough that I wont have to pay him) but at least it will get me to the strip point for the body work. |
02-28-2011, 05:24 PM | #25 |
i dont know if u have the inner fenders in or not it makes things more easy without imo i loosley bolt fenders to core suport w/core suport loose also uwant to get good door gaps first then move foward some times u must shim core support /enlarge some holes your frame could be tweeked also keep at it
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
