Old 02-23-2011, 10:44 AM   #1
LT4XTREME
Question on installing 72 bbc mounts
I'm working on a 71 swb fleetside that originally had a small block with a 3 speed. The PO swapped the 3 speed for a 4 speed now I'm switching it to a BBC th400. I got a set of 72 BBC frame and engine mounts but I'm having trouble lining up the frame mounts. Do I have to drill the front lower hole in the 71 crossmember for the 72 bbc mounts to bolt in? thanks in advance!!
Jason
LT4XTREME is offline   Reply With Quote
Old 02-23-2011, 02:06 PM   #2
sameyrasmea72
sameyrasmea72's Avatar
Re: Question on installing 72 bbc mounts
I have heard that you do have to drill at least one hole in the cross menber to add 72 BB mounts to a non BB front end. The top two holes should line up, just make sure you use the correct location on the top two. I might be able to find a pic of the top location if you need it......Jason
72 Cheyenne Super
80 Silverado Blazer 2wd
sameyrasmea72 is offline   Reply With Quote
Old 02-23-2011, 03:44 PM   #3
LT4XTREME
Thanks I had a pic but it wasn't clear about the front lower hole. I'll feel a little better drilling the hole in it now.
Old 02-23-2011, 04:05 PM   #4
leddzepp
Moderator
leddzepp's Avatar
since you have a 71 x-member, you need to drill out that additional hole. 72 x-members had the additional hole there whether or not the truck came with a bbc or sbc. no big deal, they will still fit perfectly.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
