02-23-2011, 12:24 PM | #1 |
Who has an LS in a 64-66...other than me?
I am wondering what radiator your using and what lower/upper hoses your using
Thanks!
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
02-23-2011, 12:52 PM | #2 |
65 suburban vortec 5.3 bagged
Re: Who has an LS in a 64-66...other than me?
i am going to use the stainless flex hoses they are all over ebay!!
02-23-2011, 12:56 PM | #3 |
Well, Gostranger, the reason I am asking is that I have a stainless flex hose on the lower and it is kinked pretty good. I have really looked all over to try and find a "molded" hose that will work and not have the bind that I think it has now. I have the stock upper hose ( 02 silverado), cut short and spliced with a molded (90*)hose that is the same size as the aluminum radiator intake using these...
http://www.jagsthatrun.com/Pages/Par...eSplicers.html I am looking to do the same thing on the lower....
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! Last edited by Clyde65; 02-23-2011 at 12:57 PM. |
02-23-2011, 01:32 PM | #4 |
that is why you asked i think and may be wrong but speeway had some curved or 90 degree aluminum hose connections that might be exactly what you are looking for hope this helps
02-23-2011, 01:56 PM | #5 |
I sent them an email, along with summit. I can drive my truck, but it drives me nuts just knowing it is kinked.
02-23-2011, 02:45 PM | #6 |
When I do my hoses I always get a piece of welding rod or a coat hanger, and mimic the bend I want, then go to the local auto parts store and start searching through their inventory. It usually ends up being something I have to cut down, but there's usually something that works. I have a much bigger radiator in my LS swap than the stock one, so a trimmed, factory '71 C-10 lower hose worked for me.
1964 C10 Shortened Shortbed Cammed LQ9 P&P 1967 C10 Trophy Truck BB 438 (soon to be worked on again) |
02-23-2011, 02:48 PM | #7 |
Skoffice,
When you say much bigger, how do you mean? is it the same width as stock? is the lower outlet the same place?
02-23-2011, 02:52 PM | #8 |
No I had to cut my inner fenders and whatnot, its an afco 31"x19". My lower is on the passenger side. Is the yours on the driver side?
02-23-2011, 02:54 PM | #9 |
my rad is exactly like the factory one only it is aluminum. I am thinking about making a 1.5" steel tube and connecting with small pieces of rubber hose.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! Last edited by Clyde65; 02-23-2011 at 02:54 PM. |
02-23-2011, 03:01 PM | #10 |
That's what I would do if you can't find a whole rubber one. Cheapest way to do it too. Maybe go 1.75" just to keep things uniform. I'm pretty sure that's what my water pump outlet was?
02-23-2011, 03:04 PM | #11 |
mine is the 1.75" on the rad but the LS is like 1.4" I think.
02-23-2011, 03:09 PM | #12 |
Is it that small? Dang I'd better go check that out haha maybe that hose I used was tapered.
02-23-2011, 03:22 PM | #13 |
actually 1 17/32" to be exact for the thermostat outlet.
