Old 02-23-2011, 03:23 PM   #1
rahatawa
rahatawa's Avatar
Steering Column Help
Now that the truck is running (albeit with some hiccups) and has a bed and a tag. Its time to work on the "extras"One of these is taillights. That is todays afternoon plan. The second is my steering column. The first problem is slack in the wheel. I assume I need a new box or to rebuild mine. Check. Easy enough.
The question I have for you guys is about the in-cab portion of the beast. I have search for with no luck a diagram for the exploded view of a column for my '64. My turn signal stalk just spins back and forth the column rather than moving up and down to indicate. The portion of the column isn't attached to the rest I am guessing. I need to pull the whole column apart and fix this I am guessing. I would love to get signals/brakelights/headlights all working.
If you have advice on (1)how to pull the wheel (2) what is going wrong with the signal stalk housing (3) have general advice for life and column rebuilds for someone who has never taken a steering wheel off please, please share.
Drew
rahatawa is offline   Reply With Quote
Old 02-23-2011, 03:50 PM   #2
Clyde65
Clyde65's Avatar
Re: Steering Column Help
is your column an auto or a stick?
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 02-23-2011, 04:03 PM   #3
rahatawa
rahatawa's Avatar
Whoops... Original column shift manual. So stick.
Old 02-23-2011, 04:22 PM   #4
Clyde65
Clyde65's Avatar
you need an assembly manual, it will have one in there but it really doesnt show much. I dont have a stick shift, but I know someone here will chime in.
Clyde65
Rebuild of Clyde
support our troops!
Old 02-23-2011, 04:26 PM   #5
markeb01
Senior Enthusiast
markeb01's Avatar
Perhaps this link will help:
http://www.64moneypit.pages.qpg.com/...cks/id108.html
These links may also help:
http://67-72chevytrucks.com/vboard/s...column+diagram
Old 02-23-2011, 04:37 PM   #6
daverod
SSN 706
daverod's Avatar
Thanks Mark I've been looking for somthing like that.
daverod is offline   Reply With Quote
Old 02-23-2011, 04:48 PM   #7
markeb01
Senior Enthusiast
markeb01's Avatar
This link may also prove helpful. It's for a newer series of column, but the non-tilt version probably shares some common engineering with the 64 and may indicate details to look for:
http://www.yearone.com/yodnn/tech/Te...9/Default.aspx
Old 02-24-2011, 09:58 AM   #8
rahatawa
rahatawa's Avatar
Guys thanks for all the links! those will be perfect. I will try and keep my camera handy and start a thread on my tear down and lighting party. I would love to get all my lights working. Which would be 7 if i am counting right. headlights, indicators lights in the hood, dome, and my new taillights. The idea of needing brake lights helped me realize that i might as well do them all. Checked the wiring yesterday. It is all still in place and will get out the volt meter and the wallet (bulbs, 16ga wire, Crimp connections and shrink wrap).
I feel like I am at the fun part of the build and am excited! Parked the car in the front yard so everyone passing can be jealous! Getting married on the 5th so money is tight. Getting a Mrs. and 7 and 9 year old. The 9 year old asked if he could wax the truck this weekend....
Questions. The stock front end. Does anyone have part numbers for the bulbs? Also i have two extra grills that i don't need but may get parts off of.
