02-23-2011, 11:54 PM | #1 |
Water Pump-Join In The Fun
Well, after reading several postings about 5.7L water pump failures I guess my '99 Tahoe is stepping up to the plate also. 111K miles and been seeping some for last week or two. I had looked it over and could not really tell if it was the pump or another problem so took it in and had it pressure tested. Yep, you need a w/pump Bud. Now I'm thinking would be a great time to ditch the pink Dex-Cool and go back to the ol' green stuff I've used for years. Thinking to flush and re-fill with the green, replace upper and lower radiator hoses, new 195 degreee thermostat and re-useable gasket. Do the drain and flush before the new pump install and any recommendations of a flush kit? Haven't had to use one for years, most likely have changed since the last flush kit I bought. Any thoughts much appreciated as this is Momma's ride and we all know "If Momma ain't happy, ain't nobody happy!"
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
03-02-2011, 02:45 AM | #2 |
Happy Camper
Re: Water Pump-Join In The Fun
Someone help him keep Momma happy...TTT
RIP El Jay! Love you brother! |
03-02-2011, 08:51 AM | #3 |
Has more rust than truck...
I always just take a garden hose in every opening until they all run clear. This includes flushing the rad top to bottom, take out T-stat and water top to bottom in engine and then remove the heater hoses and flush the heater core. Then make sure everything is drained and refill with a 50/50 mix. No problem so far for me using this method.
03-11-2011, 08:07 AM | #4 |
blood type; Retumbo
Thexton has an adapter (#356IIRC) for your garden hose to go into heater hoses. remove stat and reinstall housing, remove one heater hose, place adaptor into hose, attach a 4' length to nipple, flush into container until it comes clear. drain radiator and block. the block has 2 plugs. one on driver's side (9/16 swivel) and knock sensor on pass. side (7/8 deep socket). make sure the knock sensor get torqued to 15 foot lbs. refill with 50/50. then 3 months later get angry about intake gaskets leaking coolant. LOL
03-11-2011, 10:51 AM | #5 |
Well the water pump, thermostat and coolant change has been accomplished. Now, hopefully the intake gasket likes the new coolant and doesn't give problems. Time will tell.
