Old 02-24-2011, 03:23 PM   #1
smorg007
smorg007's Avatar
Cool Changing Diff Gear Oil ?
Does anybody know the capacity of SAE90 gear oil is in a 72 stock 307 geared rear differential. I can't find a drain plug so I guess options are to siphon out old oil or crack diff cover.
smorg007 is offline   Reply With Quote
Old 02-24-2011, 03:28 PM   #2
1low
Re: Changing Diff Gear Oil ?
yup pop the cover it gives u a chance to inspect the gears anyway. 2 bottles of 90wt should do it
1low is offline   Reply With Quote
Old 02-24-2011, 04:07 PM   #3
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
x2
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 02-24-2011, 04:55 PM   #4
leddzepp
Moderator
leddzepp's Avatar
pop the cover and drain. install new gasket. fill until the fluid reaches the bottom of the filler hole.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 02-24-2011, 04:58 PM   #5
cdowns
cdowns's Avatar
use synthetic
