02-25-2011, 11:30 AM | #1 |
Can I go from 17" to 16" wheels
Just found a killer deal on some factory 16" aluminum wheels.
I want to replace these steel work truck 17" with them... will they fit?
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432 '85 K30 "Big Nassy" [B]'85 C10 [B] "Corpse" '01 2500 Suburban ...party wagon & tow truck '06 Silverado SS...DD '06 C1500 WT...DD '07 Classic C1500 WT...DD Built & sold cause can't keep 'em all: '72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190 '55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938 '69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541 '86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619 |
02-25-2011, 11:02 PM | #2 |
Re: Can I go from 17" to 16" wheels
They will fit.
02-26-2011, 12:11 AM | #3 |
1998 GMC Sierra SLE 1/2 ton 2WD 305 Vortec -Gibson Stainless Cat Back Swept Side -SS Wheels 2005 Honda CRF250R 2006 Honda CRF150F |
02-26-2011, 12:35 AM | #4 |
02-26-2011, 01:11 AM | #5 |
Has more rust than truck...
Depends on what year your truck is. 99-04 can use 16s. In 05 they went to rear drum brakes with bigger front discs that require 17" rims.
02-28-2011, 11:18 AM | #6 | |
I love the look of the 20" factory wheels (found this pic somewhere surfing around), but refuse to pay $1000+ for used wheels...something good will come come up I'll just keep looking.
02-25-2011, 11:07 PM | #7 |
I don't know for sure either way, but I would check the brakes first. Those are from the last body style too, not sure if the backspacing is the same???
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
02-26-2011, 12:05 AM | #8 |
Truck Enthusiast
what year is your truck? they started putting bigger brakes in '05 when they went back to drum rears.
'85 swb |
02-26-2011, 02:36 AM | #9 |
x2 my 06 crew came stock with 17's and when i tried to put a reversed drop 17" it wouldn't clear the calipers
02-28-2011, 06:50 PM | #10 | |
Well I'll be dipped in............................ I knew about the change in brakes in 05, but didn't know about the size change.
03-24-2011, 10:09 AM | #11 |
i did on my 2000 chevy silverado and they work and look good
