Old 02-28-2011, 04:06 PM   #1
setandreel
setandreel's Avatar
lowering
Hey all. Have a 65 short stepper. All springs front and rear (coils) are original, so after 46 years i want to level out front to rear, now it has a rake, will 3 inch lowering springs do the trick or do I need more for the years of settling? Oh will be replacing only the rear spring. Thanks in advance Mike
setandreel is offline   Reply With Quote
Old 02-28-2011, 04:37 PM   #2
jimmydean
jimmydean's Avatar
Re: lowering
Might want to replace the fronts, too. Mine are stock, but have more sag than a set of cut springs.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 02-28-2011, 04:46 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: lowering
I ususally figure on at least 1" of sag in your original springs.
So if you want to drop it 3 additional inches,... I would get a 4" drop spring.
Here'a a good visual:
http://www.earlyclassic.com/Tech.asp...=Stance+Photos
Keith
Convert to disc brakes.
Old 02-28-2011, 04:51 PM   #4
Clyde65
Clyde65's Avatar
Re: lowering
For what it is worth, cuz I am no expert.
If your looking for ride quality and driveability, I would go with 2" or 2.5" dropped spindles ( depends on where you buy) and then 1.5 or 2" drop springs on the front. this way your not changing the front suspension geometry as radical. in the rear I would just go with some bags, you can do the bags with shraders and some hose for a little bit more than straight drop springs. this will allow for towing in the future too. You will also need to think about replacing bushings on the front and rear when you do the suspension.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
