03-01-2011, 01:30 AM | #1 |
Corp 14 bolt questions.
I have a 14 bolt out of a 3/4 ton truck with 3.73's in it and I have another one out of a dually with 4.56's in it.
The question is if I can take the gears out of the dually housing and put them in the truck housing. Both are in good shape and both are complete. I know the dually housing has some differences externally but will the gears interchange?
Professional hot glue and pop cycle stick engineer. 72 K/20 soon to be C/10, 454, Th400, 9” rear. 01 GMC 2500HD 8.1, Allison, daily/towpig gas guzzler. 78 Bahner 19’ jet boat, 460 Furd turd. |
03-01-2011, 01:40 AM | #2 |
gets board easy.......
Re: Corp 14 bolt questions.
Basic answer, yes
Posted via Mobile Device |
03-01-2011, 01:56 AM | #3 |
Thanks. Would you know if you need a housing spreader to get the career out? I'd like to do it myself if I can.
03-01-2011, 04:28 PM | #4 | |
Depending on your skills and tools, I would prob just cut and change perches. Good time to correct pinion angle if lowered of lifted Posted via Mobile Device |
03-01-2011, 10:45 PM | #5 |
Thanks again for your impute. Think I'll just do that, cut the perches off. The dually rear end is in better shape anyways.
03-01-2011, 02:38 AM | #6 |
I'm not sure how to go about switching the gears myself but I do have a corp 14 bolt question if you dont mind.
Mine is a 10.5" ffa w/ 4.10 gears but I can't find out for sure whether it is an open diff, lsd or gov lock. I believe its open but am not experienced enough to tell and i dont have a jack to lift it and spin the wheels. Is it possible to tell visually? I've done extensive searching and have come up blank :/ I would like to know so I know what type of lubricant to put in there. Here are a couple of pics.. thanks guys.
Life is a garden.. can you dig it? |
03-01-2011, 03:55 AM | #7 |
Barrolde
Yes, that's am open diff. I use Royal Purple gear lube in mine. Nice rig, by the way.
Professional hot glue and pop cycle stick engineer. 72 K/20 soon to be C/10, 454, Th400, 9” rear. 01 GMC 2500HD 8.1, Allison, daily/towpig gas guzzler. 78 Bahner 19’ jet boat, 460 Furd turd. Last edited by modblacksmith; 03-01-2011 at 04:01 AM. |
03-01-2011, 05:10 AM | #8 |
Thank you sir, now I can button it back up I got the green machine to learn how to fix break fix stuff and am having a blast - these boards have been a godsend!
I will go w/ the RP as you've prescribed and hopefully next time I am opening the diff it will be to put in a lsd Right, what weight do you use? The options are 75W90 75W140 80W90 85W140 90 ps. subscribed to your build
Life is a garden.. can you dig it? Last edited by barrolde; 03-01-2011 at 05:12 AM. |
03-01-2011, 05:54 AM | #9 | |
03-01-2011, 04:58 AM | #10 |
Just swap the hubs and brakes out between the two the axle tubes are the same width.
1949 Five Window, 1973 Step Side, 2000 Z71 |
03-01-2011, 05:57 AM | #11 |
But the spring pads aren't, right? I'd rather just swap the gears then cut the spring pads off and relocate them.
03-03-2011, 02:00 AM | #12 |
No worries man. Let us know how it goes
03-04-2011, 12:47 AM | #13 |
Thanks for everyone's impute on this but I had a big change in plans. I'm going to convert my 84 DRW to SRW and build my child hood dream of having a monster truck.
So I'm going to sell these axles for funding. Thanks again for your impute.
