![]() Join Date: Nov 2010
Need some help
I'm in the process of my fram off resto. My question was I bought cpp 73-87 2 1/2 drop spindles for my 1967. I drove it for a while then started the frame off. I want to buy new upper and lower ball joints do I buy 73-87 upper ball joints or 1967 ball joints also I don't see how I can replace the lower ball joints no bolts or rivets to remove are they replaceable or do I need new control arms thanks guys.
Posted via Mobile Device |
#2 | |
Re: Need some help
Lower BJ's are pressed in/out.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 03-01-2011 at 10:28 AM. |
Re: Need some help
okay thanks so bjs for 73-87 ond i should have no problem using those on my stock 67 control arms right
#4 | |
Re: Need some help
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 03-01-2011 at 11:46 AM. |
Re: Need some help
really so they were replaced at one point. thank you very much its good to know what i got now
Re: Need some help
are the bushings hard to change on these
Re: Need some help
Hard to do? Not too bad. They're just awkward because of the size & shape of the arm. It takes a little creativity w/a press or using an air chisel/hammer to drive the bushings out on 73-87 a-arms.
Re: Need some help
befor i order them just want to make sure they are the right one input please
Re: Need some help
The upper in that pic is 73-87. The lower is 6x-72 1/2 ton or 73-87 3/4/1-ton.
Re: Need some help
the upper looks the same but the lower looks diff the shaft doesnt look as think and the ends of the shaft are diff bolt vs nut help me out guys
Re: Need some help
so will they work i posted some mor pics of exactly what i got
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: Need some help
The pics of the rusty a-arms are 73-87 a-arms.
Re: Need some help
Re: Need some help
half ton or 3/4 ton...if i buy the rebuild kit does it make a diff thanks guys
#15 |
Re: Need some help
Yes.
If you have a 1/2 ton truck,... order 1/2 ton balljoints. 3/4 ton lower a-arms are different.
