![]() Join Date: Sep 2005
Trailblazer SS engine?
Has anyone used one for a swap? Theres a pretty good deal on a trailblazer ss engine with 4l70e trans.
It has a different intake manifold, exhaust manifold, accessory mounting and also has a belt driven fan. The accessories I was told mount like the chevy trucks. Oh ya also the oil is different. Anyone have any experience with this engine in a c10? I'm just worried that i might run into problems not having a vette, gto or camaro engine. |
yes, i do
Re: Trailblazer SS engine?
iirc i think the ss trailblazers had ls2s in them.
ERROR 404....... SNAPPY COMEBACK NOT FOUND ![]() _______________________________________________________________________________________________ -60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination" -07 gmt900 silverado 1500 lt xcab z71, granite blue -81 suzuki gs650g "shelah"- current project -81 kz1000m1 csr "sarge" -next project (just beautification) -07 kawasaki vulcan classic vn900 |
Yes it is an LS2, but the intake, exhaust manifolds, accessories and oil pan are all different, just wondering if I will run into a lot of problems using this engine vs a vette, camaro or gto engine?
6.0 powered square
for the oil pan I would use this http://www.jegs.com/i/GM-Performance...ductId=1221210 it comes with every thing you need for the swap. The exhaust manifolds will work well
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
Thanks Flaming. What about intake with hood clearance? Issues with accessories being in different order?
6.0 powered square
the intake and drive accessory will work just fine
GM ONLY BABY!!!
Agreed. The TB SS engine will work just fine. Maybe just have to swap oil pan. i believe those have the high mount a/c compressor so no frame clearance issues either. Wish I had a TB SS LS2 instead of my 6.0 LS out of a 01 truck.
2 wrongs don't make a right, but 3 lefts do. 66 Chevelle Malibu 406ci, 573hp, 10.99@121mph 96 Chevy Silverado Z71 72 GMC 1500 Super Custom LS 6.0/4L65 on airride ![]() ![]() http://www.cardomain.com/ride/707879...mc-c-k-pick-up Last edited by chevydog66; 03-07-2011 at 11:42 PM. |
I have a build thread on here with one, mine was out of a awd so I have to change the trans and had to swap the oil pan, I used the one that flamingbig10 mentioned and it worked fine. All accesories are the same as the truck engines except the power steering. The trucks power steering tank is a little bit different and might have to be swapped to a truck one, I haven't got my engine mounted yet to know for sure but seems like it might be a problem. The stock manifolds will work fine. I'd just make sure it's a 2wd rather than an awd, because it requires a lot more work and money. If you have any questions just ask.
Jordan 1972 Chevy K5 Blazer, 6" Lift, 35x13.5R15, 6.0/6L80E/NP205 1982 Chevy C10 SWB, 2006 LS2/4l70e In progress.... http://67-72chevytrucks.com/vboard/s...d.php?t=439860 |
![]() Join Date: Nov 2007
Vandal,
I am running a 6.0 LS2 out of a 2005 SSR which is made on the Trailblazer platform. Mine has the low mount AC compressor which I am using but it took some work. I used a late model truck oil pan and it fit fine in the truck. The Trailblazer exhaust manifolds hug the motor closer than the standard truck ones and fit great. I had to change the PS pump to a remote tank. Plenty of hood clearance. I am using the stock SSR tune with a few tweaks. I even used the cats and exhaust system all the way to the back of the cab. You will love it. Good luck. TR
1965 C10 SWB Fleet Two owner LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880 |
