Old 03-03-2011, 07:01 AM   #1
Hazieview
Building Dreams out of Dimes!
Will this fuel filler hose make two 90s? Tail light gas door build.
Hey guys I am attempting to install my hidden gas filler behind the tail light. It is a work in progress but I need your guys input.
First thing first.
Will this fuel filler hose make 2 90s in order to go into my fuel cell or do you al think it will kink?
http://www.summitracing.com/parts/GTR-58524/
Hose Size 1 1/2 in.
TeflonŽ Lined No
Hose Length (ft) 4.000
Outer Material Synthetic rubber
Hose Inside Diameter (in) 1.500 in.
It's also reinforced with synthetic fabric and steel wire to prevent collapsing or kinking.
It is pricey as hell! I need 4 feet of 1.5 ID in order to make this project work. The first 90 will be coming off of my filler neck which will be located behind the tail light which is 3" diameter by .08" thick. Base pipe 1.5" diameter.
I'm only going to be able to go 5 inches before making a hard 90. Think it will work?
Hazieview is offline   Reply With Quote
Old 03-03-2011, 07:23 AM   #2
Jeffs70
Jeffs70's Avatar
Re: Will this fuel filler hose make two 90s? Tail light gas door build.
if it was up to me I wouldn't use the rubber hose. I would go to my local muffler shop and ask them to bend a tube for me if I had to do that many bends and then maybe use a piece of rubber hose to attack the filler neck and hose together. JMO
Jeffs70 is offline   Reply With Quote
Old 03-03-2011, 07:39 AM   #3
73gmc454
73gmc454's Avatar
If you have a Napa store near you they have a real flexable hose like that and its cheaper ! I used it on my tanks ,
my build 77 gmc shortbed big block, http://67-72chevytrucks.com/vboard/s...d.php?t=438237
73gmc454 is offline   Reply With Quote
Old 03-03-2011, 08:03 AM   #4
Hazieview
I've thought of that exact same thing! Just wasn't sure how to go about it. A muffler shop would be a good source to look into for stainless piping. In fact I could get them to weld me a flange that would bolt directly to the filler neck and seal it with a rubber gasket. Then I could just use one short hose to attach that 'filler tube' to the fuel cell. It is a strait shot to the fuel cell inlet so that would be a piece of cake! Thanks! Good call!
I'll have to look into that as well. As long as the ID is 1.5 to match the filler neck that sounds good to me! Thanks!
Old 03-03-2011, 08:01 AM   #5
softballnrd27
Always a work in progress
softballnrd27's Avatar
I don't know the answer to your question but please do a detailed write up on this mod if you don't mind. I would love to do this with mine.
USMC Retired
Never trust a man who can't laugh at his own fart!
2010 Silverado Crew Cab
73 SWB 5.3/4l80e
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=695168
softballnrd27 is offline   Reply With Quote
Old 03-03-2011, 08:11 AM   #6
softballnrd27
where did you find that fuel filler? Not the hose
USMC Retired
73 SWB 5.3/4l80e
Build Thread:
Old 03-03-2011, 11:12 AM   #7
dropd80s
dropd80s's Avatar
The pic he posted is from www.performanceonline.com couldn't find it on their site though.
dropd80s is offline   Reply With Quote
Old 03-04-2011, 07:16 AM   #8
Hazieview
http://www.performanceonline.com/POL...000-SSF0000895
I also have one of there fuel cells installed in my truck. Only mine had to havea custom filler coming out of the rear of the fuel cell instead of through the bed. This prevents me from having to cut a hole in my bed. That is only if my gas door idea works.
Old 03-04-2011, 12:52 PM   #9
pig rig
pig rig's Avatar
you can also go to your local autoparts store and get pre bent 90's and cut them down to what you need.
its pretty easy to turn a 90 into a 45 or a 22
my sports car rolls on six wheels only because I'm to fat to get in and out of new corvette
http://hubgarage.s3.amazonaws.com/ph...ped_detail.JPG
pig rig is offline   Reply With Quote
Old 03-03-2011, 11:21 AM   #10
Jonboy
Slots go on anything!
That size is common on boats, too. You might cehck into some marine sites as well.
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
Old 03-03-2011, 11:31 AM   #11
N2TRUX
Happy to be here
N2TRUX's Avatar
Look for a "performance" type muffler shop that has mandrel bends. That will give you a lot less restriction than standard bends.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 03-03-2011, 12:56 PM   #12
silvereagle07
silvereagle07's Avatar
Check out the fuel filler products from Hagan Street Rods. They have a better looking fuel cap system. http://www.haganauto.com/fuel_doors_gas_lid_s/5.htm
I've been looking into doing this also but I don't have the time it requires. Here is a version that I was going to adapt. But beware! It's on a old FORD. I just like the fact that it slides out and it's held by a claw style latch. It should be very easy to adapt.
Jeramy
'84 GMC project truck
'85 Chevy 4X4 SOLD
'07 Chevy Trailblazer SS
5th Annual SHPHC Car/Truck Show Pics
http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT
silvereagle07 is offline   Reply With Quote
Old 03-04-2011, 07:13 AM   #13
Hazieview
You know... I never thought of that... That is a dang good idea!
Man I like the idea of that hinge and latch. Checked out there website and it would only be like $30 for both. I bet I could make them work! Cool!
Door latch $10
Door hinge $20
If it worksi t will be a great investment! Thanks I've never even heard of these guys!
Not sure If I'm sold on the gas cap.... I'll have to think about that one... It would be pretty handy in a tite spot such as behind the tail light because this cap does not need to be removed in order to fill your gas tank.
I'll have to think about this one.
Old 03-04-2011, 06:42 PM   #14
silvereagle07
Door latch $10
Door hinge $20
I was thinking of using a pop up style gas cap like on custom motorcycles like this one. It's just an example. There is a lot to choose from. Sorry that pic is huge.
Jeramy
'85 Chevy 4X4 SOLD
Old 03-05-2011, 11:36 AM   #15
502ss
502ss's Avatar
That hose won't kink because it is fabric and steel wire reinforced but it also won't be able to make really tight bends. I am right in the middle of tail light gas door mod(pics can be seen in my build thread) and I am going to have an exhaust shop bend me up my connector. It takes a little more work to make sure you tell them the right angles and lengths but in the end it will fit better then a large bend radius hose.
1984 CC Dually - 454 - TH400 - Western Hauler Edition
Big plans are coming!
My build thread HERE
502ss is offline   Reply With Quote
