TexasJimmy 71' Blazer Initial Start Up... 03-03-2011, 09:57 PM
AJs72K5 Re: 71' Blazer Initial Start... 03-03-2011, 11:06 PM
my90k5 Re: 71' Blazer Initial Start... 03-04-2011, 12:03 AM
TexasJimmy Re: 71' Blazer Initial Start... 03-05-2011, 12:19 AM
03-03-2011, 09:57 PM | #1 |
71' Blazer Initial Start Up Advise
I will bring my new 71' Blazer home on Saturday. It has set up in a garage for 3 years. This is how I plan to start it for the first time. Any advise is welcome.
1. Drain fuel tank, and add fresh gas. 2. replace all fluids. 3. Pull plugs and add ATF to cylinders. 4. Disconnect fuel line at carb. 5. Crank until fresh fuel is seen without spark plugs installed. 6. Replace plugs and crank it up. 7. If float is stuck, tap on carb to release. Am I miising anything? Thanks Tim Here are some pics......... http://www.kodakgallery.com/gallery/...14%3A594592991 |
03-03-2011, 11:06 PM | #2 |
Re: 71' Blazer Initial Start Up Advise
Link doesn't work Tim.
Posted via Mobile Device |
03-04-2011, 12:03 AM | #3 |
72 K/5 Junkie
No pic's on the link....
I used marvels mystery oil in each of the cylinders when I started mine up after 1 year (prob same as trans fluid). Would like to see some pic's tho. |
03-05-2011, 12:19 AM | #4 |
Lets try these....I just got it home tonight. I will keep you posted. The rig was purchased about 40 miles from my house in 71'. One family owner. All records, manuals, and even the protecto plate. http://www.kodakgallery.com/gallery/...hotos-_-Sharee http://www.kodakgallery.com/gallery/...hotos-_-Sharee |
