03-03-2011, 11:16 PM | #1 |
Suggestions on Dash
What would you use to remove all this crap on dash? Thank You in advance.
1972 K1500 Longbed 350 w/3 on tree. 1976 Chevy Nova 350 auto 1972 C10 (donor) |
03-03-2011, 11:33 PM | #2 |
Re: Suggestions on Dash
Adhesive remover might work.
03-03-2011, 11:37 PM | #3 |
they make some stuff called oops. may have to soak it a time or two.
1972 C10 SWB Cheyenne- Tubbed, 4link, 6.0, etc. 1970 C10 SWB - Work in slow progress 2013 GMC 2500 Denali - Deleted |
03-03-2011, 11:44 PM | #4 |
If you have a can of WD40 around try this before buying anything. Work in small sections, spray some WD40 on, let it soak in a little and use a rag and rub, keep spraying as you go along, it might break it down enough to where it will come off.
66 GMC Suburban Custom 66 Chevy K10 Suburban |
03-04-2011, 01:40 AM | #5 |
WD40 works great on stuff like that usualy. And it smells kinda pretty to me...
71 2wd Blazer My build, Restarted 05 Buell firebolt 94 1500 Z71 No rice for me,,, I'm full |
03-04-2011, 06:23 AM | #6 |
WD40 Does work great, I agree with this the only problem with WD40 is if you plan on Painting any surface after using WD40 you might want to clean with something else that will wear off the WD40 and allow paint to stick.
My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=442487 My Picture Gallery http://67-72chevytrucks.com/gallery/...0&ppuser=36004 |
03-03-2011, 11:45 PM | #7 |
Old Skool Club
Your dash pad will cover it up, right?
3M makes an adhesive and woodgrain remover. It comes in a quart can. I'm sure there's some acetone in the mixture, so be sure you have plenty of ventilation. Also, wear some gloves that will protect your hands. When you put your new dash pad on it, it should be covered up.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
03-04-2011, 12:09 AM | #8 |
Thanks for all the suggestions hopefully I get some time to work on it this weekend.
I know everyone likes pics.
03-04-2011, 12:44 AM | #9 |
"Goo Gone" For sure. I use it for almost everything. Old stickers, window tint residue, ect.
You're not old, it IS loud! 1970 CST-10 BB 400 |
03-04-2011, 06:14 AM | #10 | |
Words under my name
69 Chevy CST/10 "Project: Bloody Knuckles" my slow going project. 2010 VW Golf, daily driver Wrench Rookie Last edited by steelscout; 03-04-2011 at 06:14 AM. |
03-04-2011, 02:13 AM | #11 |
+1 for Goo Gone. Used it for decals on the side of dump trucks and tractor trailers. No residue and pretty cheap.
03-04-2011, 08:45 AM | #12 |
Contractors Solv-It is what we use here at work. You can usually get it at hardware stores. Smells like oranges and works great. Spray it on, let it sit, wipe it off
03-04-2011, 09:16 AM | #13 |
NEVER use WD-40 anywhere you intend to paint. Just one hidden drop will ruin the paint job. My painter won't even let one can be anywhere in the shop.
72 Fleet (died) 78 Step (sold) 55 Step named Fred (sold) 00 F150 68 Step (named El Scorcho by PO) Build thread for the new El Scorcho http://67-72chevytrucks.com/vboard/s...d.php?t=392932 |
03-04-2011, 09:27 AM | #14 |
Is is getting repainted? If so sand it off or wipe it with laquer thinner. That should do the trick.
68 lwb to swb Cummins swap in the works. I promise it will be cool someday. |
03-04-2011, 09:59 AM | #15 |
acetone or lacquer thinner ON A RAG ... do NOT pour it directly on the dash ...
03-04-2011, 10:07 AM | #16 |
I am a Referee of life.
The above suggestions will probably work.I would suggest trying them first and if they don't you can clean it well with a fine steel wool and then use rubbing compound and wax to bring on the shine.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
03-05-2011, 09:34 PM | #17 |
Thank you to all for the suggestions. I just ended up leaving most of it I just used some purple power and scotch brite and then installed new dash pad.
03-05-2011, 11:40 PM | #18 |
looks good!
