03-04-2011, 01:08 PM | #1 |
Right forum?? transmission leak issue
Found my leak, I think its the transmission dipstick tube.
What the best way to fix it, I'm new to all of this. Just got my truck about a week ago. Thank you, if this is the wrong forum .....sorry.....
'71 Chevy LWB all OG '86 Chevy LWB all OG It's all a matter of perception |
03-04-2011, 01:19 PM | #2 |
20' Daredevil (Ret)
Re: Right forum?? transmission leak issue
I think there is an o-ring at the base of the tube, where it joins the transmission case.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
03-04-2011, 01:27 PM | #3 |
is this a typical leak area...
03-04-2011, 01:57 PM | #4 |
I think that it is fairly common. I had this issue with a ford van that I had. basically what happens is when they sit, the transmission fluid rises up into the tube which then needs to be sealed with the O-ring. when the vehicle is running, the fluid lowers and will not leak. so if it appears to be leaking while it sits then it is probably the O-ring. definately replace it.
