02-20-2002, 11:52 PM | #1 |
dumps or side exit? (and other exhaust stuff)
So i'm putting new exhaust on my '84. I'm pretty set on using 40 series flowmasters, i know some of you guys don't like em so here's your chance to talk me out of it. Also i know the flows will give me alot of interior resonance. I want to just dump the pipes before the rear axle. Will this make it even louder inside? would side exit before the rear tires be any better? For you 67-72 guys who don't have to run cats, since i'm going to run some after market cats won't these make the 40 series a little quiter than they are on your trucks?
sorry so long but i want some input so i can make up my mind and order stuff ------------------ '84 1\2 ton swb, 350 5\7 drop just sold '64 1\2 ton 4\4 drop with built 350 (my toy)
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works '05 1500 Crew Cab RIP '84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker '80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's |
02-21-2002, 07:47 AM | #2 |
BAD BOW-Silverado XST
low 84,
I run a single 40 series Flowmaster with a cat (blown out by accident ). That one makes enough sound for me. Two would awsome. I can drive at highway speeds and the noise is not a problem. I hear more noise from the vent windows. At low speeds it sounds very nice. The loudest sound seems to be around 1100-1300 RPMs. Mine single dumps infront of the axel. The resonance at idle when parked sounds really good. If you use some sound killing material under the carpet and put some 12' thumpers behind the seat like me you wont hear a thing. ------------------ Gerardo 1983 Custom Truck TX Plates: "BAD BOW" http://www.geocities.com/abetterchemist/ |
02-21-2002, 11:08 AM | #3 |
sounds good gchemist thanks for the info
02-24-2002, 11:28 AM | #4 |
its all about the +6 inches
Yes, running a cat will quiet id down quite a bit. The wife wanted a flow master for her POS S-10 Blazer, and I got a 3 chainber thinkin you'd still be able to tell it was there...I know it's there, only becouse it cost so d@mn much.
One thing to think about, make sure there is plenty of space all around the muffs. Flowmasters have been known to cause fires being that they get so hot. ------------------ '69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it. Need to pick up the one ton Longhorn with a PONTIAC 350/350soon. Thanks every one! Check out The Longhorn Webite. If you need a pic posted, E-mail me at longhornmail@yahoo.com Andy, in Columbus Ohio |
02-27-2002, 01:22 PM | #5 |
I'm back with 2nd truck!
I run dual flowmasters and dump them before the axle. I have a MP# of it if you would like to hear it. Email me and I will send it to you. Also here is a link to where I have pics of my exhaust set up. http://www.geocities.com/cjhicks1/exhaust.html
------------------ BRANDON 1979 CHEVROLET BONANZA BIG10 350 GM Crate Engine ZZ4,1406 Edelbrock, 1 5/8" Heddman Headers 2 1/2" Dual Exhaust with X pipe and Flowmaster 40 Series Mufflers,350 Turbo Transmission,3.07 Gears My website for the truck.
1979 Chevrolet Bonanza Big10 "Tootsie Roll" 1985 Chevrolet Silverado (wife's) Member of the Southern Bowties Club "Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson |
03-08-2002, 09:00 PM | #6 |
Hey 79BIG10, I cant get the audio to work on your website. Can you email the sound clip to me ? thanks
05-13-2002, 03:22 PM | #7 |
I had a 74 gmc with hooker comps, h-pipes and flowmasters dumped right after the muffler all 2.5". WOW what a rumble at low idle. It was awsome. Made you want to stomp on it. Set off car alarms inside parking garages all the time. The shop that installed the system told me to dump it was acually better. All the extra after the mufflers was only to get the fumes to the rear and caused restriction anyway. The only drawback was if you travel on dirt roads it really boils up the dust. So just a pair of turn downs are the best. The turn down helps to draw also from the air under the rig while your sailing down the hwy. This system upped my milage and power. Sold the truck back to the original owner and she prefers to drive this plane jane farm truck over her lincoln town car. And she is a tiny little 60yr old indian lady. Quite a truck.
05-14-2002, 06:03 AM | #8 |
Did y'all know that Flowmaster actually recommends you don't drump your exhaust after their mufflers!!! I'm changing mine once the 350 goes in. I think I'll do a straight pipe after the muffler with just a tad of dump.
------------------ Gerardo 1983 Custom Truck TX Plates: "BAD BOW" |
05-18-2002, 02:10 AM | #9 |
driving is in my blood
Im going to put ramhorn 2.5's to true dual w/h-pipe to 40 series side exiting before the rear wheels with z28 style "vaccum" tips on my 79 with a vortec 350. I have 1 5/8" headers to true dual 2.5 w/h-pipe to 40 series then going all the way back to 4" [maybe 3 or 5, I really dont remember] megaphone tips on my 78 with a 383 and it sounds absolutly awsome. Not the extreme muscle car sound like flowmasters dumped, but at 6k this thing sounds EXACTLY like a NASCAR going by you on the track. Interior resonance is pretty bad though, even when I had a $2500 sterio in it.
------------------ 78 c10 short/stepside: 383/M20/12 bolt 79 c10 short/wide: vortec 350,th350/12 bolt 99 accord v6: 200hp 3.0L, high flow intake tube w/ K&N, much more to come [think classy, not rice!]
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
06-07-2002, 12:39 AM | #10 |
other options for side exhaust or tips
check out www.spintechmufflers.com , and send for thier literature they have a virtual smorgusboard of mufflers, tips, and pipes, of all shapes and sizes, if they don't have what you want they will make it.
06-12-2002, 11:32 PM | #11 |
holy crap! i can't belive this post is still alive. i haven't been on this board in awhile. i posted this 4 months ago. the exhaust has been installed for a while and sounds great
later, ryan
