I have a 85 chevy C-30. I converted the manual transmision over to a turbo 350 automatic. I can not for some reason bolt the 85 automatic transmision flywheel to the 350 torque converter. I have been told I need to use a 400 torque converter so that it will bolt up to the 85 454 flywheel.
Please give any input you can. All will be very much needed. |
king $h!t
yep this is true
j dawg the 86 allmost done 357/700r4/lifted 9/dana44 front ten bolt rear/3.73 gears/35s |
454 use different set up/pattern than all other engines except SB400, there are small and large patterns
good luck |
