03-07-2011, 03:41 PM | #1 |
Key switch removal
Hey guys I have lots the key to my truck and I desperately need to move it. I already have the steering wheel off but now I am stuck if any one can help me from this point it would be much apreciated. I just need it to drive down the road.
uhcostuh 78k10,84k10,86c10,87k10 |
03-07-2011, 03:58 PM | #2 |
Re: Key switch removal
There is a tool for removing the lock plate that makes it much easier to take apart.
Tilt & non tilt both have a lock plate so here are some steering column sites with photos that tell how to repair loose tilt columns. The photos should be helpful. http://www.fieros.de/en/articles/steering.html http://elcaminocentral.com/article95.html = does not work anymore Looks like on this site he did the quick fix and did not take it apart far enough to tighten all four fasteners. http://www.chevyasylum.com/column/tiltcol.html Older car but good photos http://buickperformance.com/tiltstee...lumnwobble.htm
For those of you that are wondering why you are not getting replies to your thread: Did you give the model, year, engine, fuel system type, and transmission information? If it is modified from what came stock from the factory, let us know that too. |
03-07-2011, 04:01 PM | #3 |
what is they lock plate? Is it that gear looking thing you see in the pic?
03-07-2011, 04:10 PM | #4 | |
It locks the column so it will only turn when the key is turned.
03-07-2011, 04:11 PM | #5 |
do they sell these tools at advance?
03-07-2011, 04:13 PM | #6 |
Yes, the tool will push that plate back a bit towards the engine compartment, then you can pry out the round little clip from the middle shaft with a flat screwdriver. That will allow you to take the whole plate off, pull the turn signal assembly out, and finally get to the back screw holding the ignition assembly in place.
A word of advice, either rent the tool or buy it. Without it is going to be a MAJOR headache. Some people have even made their own. I bought mine at Autozone.
Fernando Project "FATBOY" build thread The key to happiness is having dreams. The key to success is making your dreams come true. Last edited by HumbleChevyBuddy; 03-07-2011 at 04:13 PM. Reason: Added more info..based on the last question. |
03-07-2011, 04:15 PM | #7 |
This is what it looks like:
Fernando Project "FATBOY" build thread The key to happiness is having dreams. The key to success is making your dreams come true. |
03-07-2011, 04:34 PM | #8 |
Yeah that is probably what I am going to do. Is it simple after you get that plate out?
