03-07-2011, 03:50 PM | #1 |
Narrowing a rear end
how hard is it to narrow a 10 bolt rear end I need it to measure 54 inches it measures 57 now from the backing plates. Do I have o get new axles or can you re spline the existing ones. Does anyone know or have an idea what this will cost?
03-07-2011, 04:22 PM | #2 |
Re: Narrowing a rear end
not worth the money or effort compared to a pair of new wheels with a bit more backspacing
03-07-2011, 04:42 PM | #3 |
I wish I could I cant send them back
Posted via Mobile Device |
03-07-2011, 05:48 PM | #4 |
Happy to be here
Will this be close enough?
03-07-2011, 06:20 PM | #5 |
What year/model 10-bolt?
03-07-2011, 08:48 PM | #6 |
10 ten out of an 88 model truck, how bout using an 94-96 impala ss rear end since it has disk brakes?
03-07-2011, 11:39 PM | #7 | |||
03-08-2011, 01:16 AM | #8 |
Yes I need 54 inches so my wheels will work, so it looks like I need some new axles
03-08-2011, 01:38 AM | #9 |
The 88-98 housings are about .750" wider per side vs. 71-87's. The 71-87's are .750" wider vs. the 6x-69's. Sounds line the 62" wheel mounting surface to WMS of the 6x-69 truck housing would be the right dimension or narrowing your current unit.
What year truck? What size & back-space on the wheels in question?
03-08-2011, 10:39 AM | #10 |
88 model truck the wheels are 22x 9.5 with a 4.5 backspace, what exactly is 6x-69s rear end
