I know many people have asked about swaps but i couldnt find any answering this question. If you have a 2wd pickup and use a 700 out of a 4x4 what it the difference? i know the output shaft is different length but i would have to shorten the driveshaft anyway so what else is different. can you even use a 4x4 700 for a 2wd pickup? and i know about all the TV cable and lockup wiring so im not worrying about that.
Thank you for your time, Logan
1969 C-10 LWB 388 SBC Vortec Heads 10:1 Lunati 60103 cam Weiand intake Quadrajet Carb 12 Bolt 3:73 posi 700r4 Hedman Headers 1998 Dodge Ram 1500 Reg. Cab Long Box 4X4 5.9L 183k miles 1956 Ford F-100 Longbed with Original 272 and 3OTT 1995 C1500 ECSB 6.5 Diesel 4l80e (Camper puller) 1997 Dodge 3/4 ECLB V10 (MPG machine) ![]() |
Re: Another 700R4 Swap Question
You can use a 700R4 out of a 4X4 but you will need to change the output shaft to the 4X2 along with adding the tailhousing. The 4X4 has no tailhousing and nothing to seal to the driveshaft, so basicly get a 700R4 from a 4X2. There are more 2wd 700's then 4wd ones, think of all the big GM cars that have 700R4/4L60 before 1993.
Lifes journey is not to arrive at the gate well preserved, it is to slide in sideways all used up and wore out yelling.....God what'a ride! Where patience fails, force prevails Stapp's Ironical Paradox "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle." |
There is a guy near me selling a 4x4 one for $75 so i thought is it isn't too costly i could just swap that stuff. i would have to rebuild it anyway so i thought it might be worth it. does any place sell the tailshaft and different output shafts?
