Old 03-09-2011, 12:24 AM   #1
69BB396
69BB396's Avatar
Cool Drop Spindles and Tie Rod Length, 69 C10
Installed the CPP front 2.5drop spindles w/discs that allow using stock tie rods. Installed new PS gear and pitman, and found centre by rotating (2.5 turns side to side therefore 1.25 is center). Installed center link and idler, then assembled tie rods.
Problem: with tie rods at minimum length, I can see they are a bit too long and both rotors are a bit outward at the front. I haven't used a string yet to
get a better reading, but I think I need about an Inch or so on each side.
What is the best fix? Is it safe to trim the tie rod lengths to get fitment?
I checked the new parts with the old, all sizes seemed correct.
My center link is original.
Ron
69BB396 is offline   Reply With Quote
Old 03-09-2011, 11:25 AM   #2
Clyde65
Clyde65's Avatar
Re: Drop Spindles and Tie Rod Length, 69 C10
you should be able to turn the adjustment sleeve and that should move the inner and outer tie rod so the wheel moves in the direction you need, i dont think I would do this with the truck on the ground though. I would also get the measurement of the back and front of the front tires. for temporary use, I think 1/2 inch of toe in should be ok for a quick trip to the alignment shop, as long as it isnt too far.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 03-09-2011, 12:37 PM   #3
69BB396
69BB396's Avatar
Truck is up on blocks, wheels and tires ordered but have not arrived yet.
I have turned the adjustment sleeves as far as they will go, assembly is still too long - I think I have "toe out" ? Looking from engine rear-ward, the rotors are angled out at the front.
Old 03-09-2011, 01:33 PM   #4
Clyde65
Clyde65's Avatar
have you spoken to Jeff from CPP? give him a shout, he is here on the board. I dont understand why it would be different if they are the same length as the old ones, did you size them up b4 you installed them ( make them the same length as the originals) b4 installing?
I didnt have any problem at all, but I also replaced the sleeve. that shouldnt matter though
Call Jeff. best option right now.
Clyde65
Rebuild of Clyde
support our troops!
Old 03-09-2011, 01:57 PM   #5
69BB396
69BB396's Avatar
I didn't measure the old, but I did check each new part against the old. I have new sleeves too, and the complete spindle/brake setup is new.
Also, I just assembled the passenger side, length needed here is longer and works OK
Thanks! I'll try to find the CPP guy.
Ron
Old 03-09-2011, 02:13 PM   #6
69BB396
69BB396's Avatar
Here's some photos;
Old 03-09-2011, 02:25 PM   #7
Clyde65
Clyde65's Avatar
adjuster sleeves the same length?
Clyde65
Rebuild of Clyde
support our troops!
Old 03-09-2011, 02:35 PM   #8
69BB396
69BB396's Avatar
Measured, 6.5" both sides. Maybe a shorter one for driver's side would be the fix?
Ron
Old 03-09-2011, 03:48 PM   #9
Clyde65
Clyde65's Avatar
man, IDK, I would call CPPJeff!
Clyde65
Rebuild of Clyde
support our troops!
Old 03-10-2011, 04:06 PM   #10
69BB396
69BB396's Avatar
I wonder, is it possible that the steering box does not need to be exactly on-center...... If I moved it say, 1/8 or 1/4 turn, this would move the center link over enough to be OK. (it may thow out the passenger side though)?
This would also affect the turning radius side to side, unless the spindles touch the stops before the gearbox reaches its turn limit?
Thoughts?
Ron
69 396BB Turbo 400 Fleetside, 3:07 Gears
2.5" & 4" drop
2020 Silverado 2500LT
2006 Subaru Forester
2019 Chevy Cruze
Old 03-10-2011, 04:25 PM   #11
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Might just be me, but those adjustment sleeves look too long.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 03-10-2011, 06:57 PM   #12
fishingjred73
fishingjred73's Avatar
I think your right.
James
'68 Stepside (ground up in progress)
My 68 build thread http://louisianaclassictruckclub.fre...side-t956.html
'81 SWB "Pap paw" (Driver)
The 81 build thread http://louisianaclassictruckclub.fre...-swb-t960.html
Member of
www.louisianaclassictruckclub.com
https://www.facebook.com/groups/296290610747732/
fishingjred73 is offline   Reply With Quote
Old 03-10-2011, 09:57 PM   #13
Hubscrub
Cruzin
Hubscrub's Avatar
adj. sleeves to long x3
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 03-10-2011, 04:22 PM   #14
Clyde65
Clyde65's Avatar
Let me look at my truck and Ill let you know tomorrow. with the wheel straight, I will look at the tie rods and the steering box
Clyde65
Rebuild of Clyde
support our troops!
Old 03-11-2011, 04:09 PM   #15
69BB396
69BB396's Avatar
Hey thanks, if you're under there, measure the length of the sleeves?
I cross-referenced TRJ or Moog part numbers on the NAPA website,
their sleeves show 6".
Wes from classic heartbeat says his are 4.5".
Also hope your friends and family are all safe away from the Tsunami problems
Ron
2.5" & 4" drop
2019 Chevy Cruze
Old 03-11-2011, 04:25 PM   #16
lolife99
67-72 parts collector,…
lolife99's Avatar
I got this info from CPP's website.
Tie rod lengths:
ES323L 1960-64 outer, 5/8-18 4" left,
ES350L 1965-70 outer, 5/8-18 7.9" left
ES415R 1971-72 outer, 11/16-18 6.36" right
ES631 1960-62 inner, 5/8-18 8.66" right
ES678 1963-64 inner, 5/8-18 6.66" right
ES370R 1965-70 inner, 5/8-18 8" right
ES403L 1971-72 inner, 11/16-18 8.79" left
Tie rod sleeves:
ES350S 1965-70, 5/8-18 thread, 6" length
ES2004S 1971-72, 11/16-16 thread, 4-3/4" length
As you can see the 71-72 tie rod sleeves are shorter,... but the 71-72 tie rods themselves are much longer,... plus they won't help you anyway.
Do these numbers confirm what you have?
Keith
Convert to disc brakes.
Old 03-11-2011, 04:36 PM   #17
lolife99
lolife99's Avatar
These are the fix to your problem.
Edelbrock's custom tie rod sleeves.
I like them much better than the clamp setup anyway.
I try to use them on all my trucks.
Edelbrock part #5250 (5/8" x 3-3/8") short version
Edelbrock part #5251 (5/8" x 4-7/8") long version
I would just buy the 4-7/8" version and you should be set.
These can be purchased from Jegs or Summit Racing.
I have a set of tie rod sleeves similar to these from POL,... but the Edelbrock version is much nicer looking for the less money.
Edelbrock # 5251 is $35.99 from Jegs.
POL sells theirs for $49.99.
Keith
Old 03-11-2011, 04:18 PM   #18
lolife99
lolife99's Avatar
I think the 71-72 sleeves are shorter,... but they are 11/16" thread.
Yours are the smaller 5/8" thread that is used on the 67-70 trucks.
Keith
Old 03-12-2011, 12:50 AM   #19
mr48chev
mr48chev's Avatar
I posted over on the Classic heartbeat site but are you sure that by "stock" tie rod ends and sleeves CPP means the 70 and earlier or do they mean 71/72 parts? I checked their site and it was pretty vague as usual on their stuff.
Also check the lengths of your sleeves you put on the truck. They should be six inches long even.
Old 03-12-2011, 09:13 PM   #20
69BB396
69BB396's Avatar
lolife99 wins! Taking my sleeves back to NAPA, intalled these;
Thanks to all for your efforts. Ron
2.5" & 4" drop
2019 Chevy Cruze
Old 03-12-2011, 09:24 PM   #21
69BB396
69BB396's Avatar
Thanks, I got your reply on the CH site. I found crossreferencing numbers can be misleading. NAPA can crossreference MOOG and TRJ numbers, what comes up as proper for my truck with power steering is 6.5 inches.
I also discovered that these sleeves are not threaded through the entire shaft - there's a section in the center not done. And this sleeve is not split down the center like the others. That's why the tie rods won't adjust close enough.
Cheers
Ron
2.5" & 4" drop
2019 Chevy Cruze
Old 03-14-2011, 01:17 PM   #22
lolife99
lolife99's Avatar
I read this quote,... and thought you were talking about the Edelbrock version.
I glad things worked out.
I thought maybe Edelbrock had changed their design.
Keith
Old 03-12-2011, 09:56 PM   #23
lolife99
lolife99's Avatar
So the Edelbrock sleeves don't work?
Keith
Old 03-14-2011, 12:47 PM   #24
69BB396
69BB396's Avatar
Yes, they do - and thanks. They also saved me $50 bucks! The ones from NAPA were 52 each. Took them back. See my pics back on this thread.
Ron
2.5" & 4" drop
2019 Chevy Cruze
Old 03-18-2011, 01:52 PM   #25
CPPJEFF
Ron
This is totally great news. I actually make those sleeves exactly like that and they are $49.00.
CPPJEFF is offline   Reply With Quote
