How do I get gauge cluster out?
I wanted to take out the gauge cluster but I couldn't get the wiper switch to come out. I need to take this out so I can replace my dash pad. Is there a way to replace dash pad w/o removing gauges?
People know me
Re: How do I get gauge cluster out?
there is a small flat head screw on the knob
1972 k/5 blazer CST 4X4 Crate 350, th350/205, dana44with trac-loc/14 bolt with detroit locker, 4 wheel discs 4.56s, 8" suspension lift using 73-87springs, 1" zerorate custom front crossmember, HAD CV drivelines and driveshaft e-brake, full cage, PRP seats, Full autometer gauges, 38x14.5x16 Toyo M/Ts, 16x10 Polished aluminum rockcrusher wheels 1967 longbox 4x4, Strong 400/400/208, 44/12bolt 4.10s, 6" lift, 35" Toyo M/Ts on corvette rally wheels |
![]() Join Date: Jan 2007
C'mon Mario - you have had your Blazer for how long and you haven't taken out the gauge cluster? I do that first to clean it up a bit...
http://67-72chevytrucks.com/vboard/s...d.php?t=164357 |
![]() Join Date: May 2006
Isn't there just 4 screws that hold the dash pad in, been so long I forget
@ bigbad, is the screw behind the knob? I pulled on it and it didn't come off. Do I even need to take the gauge cluster out to get to the dash pad bolts? @ Lksdcvn, you know me Tom, I've had that dash pad for nearly two years. I just drive the thing. @ jaros, I took the four screws out and that sucker didn't want to come out.
i didn't have to take the cluster out to take the pad off....looks like i GOT SKILLZ
'72 K5 CST Blazer 4x4 in perpetual progress '96 2dr Tahoe 4x4 daily driver, Black Bear Performance tune, 285-75-16 Nitto Grapplers, Magnaflow muffler, K&N Air filter, Bilstein Shocks.........E-fan, DT Tri Y or Pacesetter LTs coming soon |
The wiper switch on the right on the gauge cluster has a screw on the knob that holds it on to the rod in the switch. The light switch on the left of the cluster is trickier in that their is a small push button that you push in and pull the knob and rod out in one piece. You'll need to reach under/behind the cluster to get to the top of the switch itsself and feel the button to push in.
I haven't replaced my pad yet, but from looking at it before, it seems it would be easier if the cluster was removed. Good Luck
'71 ![]() "If life was fair you'd be able to afford one of each and a garage large enough to house them all." |
