03-12-2011, 12:05 PM | #1 |
Under bed fuel tank solutions for 55-59 pickups (under $300.)
I was wondering if anyone knows a source for fuel tanks for the 55-59 Chevy/GMC crowd. I would like to get an under-bed setup for $300. or less. It doesn't matter what material it is made of. I also need it to be compatable with my stock fuel gauge. Any suggestions, sources, and part #'s would be appreciated greatly!!!
1957 Chevy Pickup 1/2T, stepside, big window, 77' Camaro subframe, 3rd gen Firebird rearend w/3.23 gears & disc brakes, 66' 283cid, TH350 auto, everything else is original |
03-12-2011, 01:52 PM | #2 |
Re: Under bed fuel tank solutions for 55-59 pickups (under $300.)
69 mustang tanks 129 bucks, is what I used.
'57 Chevy Pickup '56 GMC LCF Cummins '38 Chrysler Royal '57 2wd change http://67-72chevytrucks.com/vboard/s...light=speedway |
03-12-2011, 06:57 PM | #3 |
I would be interested in seeing some pics of this setup. Did you use the 69' sending unit as well?
03-12-2011, 02:15 PM | #4 |
I had one made at Boyd Welding down in Florida,aluminum well constructed.
03-12-2011, 02:23 PM | #5 |
Here is an article: http://www.webrodder.com/article.php?AID=442&SID=2&CID=
03-12-2011, 08:36 PM | #6 |
No I have an LS motor so I used and chevy late model intank pump and unit. Search for mustang tank several guys have used it.
'57 Chevy Pickup '56 GMC LCF Cummins '38 Chrysler Royal '57 2wd change http://67-72chevytrucks.com/vboard/s...light=speedway Last edited by blackdiesel; 03-12-2011 at 08:37 PM. |
03-12-2011, 09:42 PM | #7 |
I used the mustang tank as well. Ebay has them on the inexpensive side. I used the GM sending unit and tweaked the float and sending unit. I have not tried the sending unit yet but I expect it all to work out.
One day I am going to finish this project! 1949 Chevy 1/2 ton |
03-12-2011, 09:49 PM | #8 |
i used a summit racing fuel cell , 25x17x9" , has a built in 90ohm sending unit . i just drilled out a few rivit's and moved the very rear x-member back 2-3 inches and used summits mounting brackets ( you could make your own) i dont know how the filler is gonna work yet as i havent put the bed back on yet . 159.95 for the fuel cell , 32 bucks for the mounting brackets
03-12-2011, 10:36 PM | #9 |
A320 Pilot/USAF Retired
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
03-12-2011, 11:10 PM | #10 | |
03-13-2011, 12:43 AM | #11 |
did you end up using the mustang tank as a top fill or a rear fill?
03-13-2011, 09:18 AM | #12 |
I didn't use that particular one, but mine is from Tanks, it was their universal tank they made in the past in steel. I don't think they make it anymore. It looks like the poly tank would fit betwenn the frame rails real nice and not hang down to low. As far as it working with the stock gas gauge, you would have to match the sender's resistance, and I don't know what the stock gauge range is. Are you planning a EFI engine for your's, if not you wouldn't need the in tank pump. Good luck!
03-15-2011, 11:44 PM | #13 | |
03-16-2011, 12:55 PM | #14 |
Poly is ok if it is protected, I had a steel auxilary tank in the spare tire location originally and decided to go with the aluminum one after looking at all the dents and scrapes in the steel one from off road use. If you are going to just be driving around town and its tucked up high enough to avoid parking bumpers, etc. then it should be ok lots of guys use them.
03-16-2011, 08:43 PM | #15 |
I think it will be a good choice, let's see some progress pics!
03-17-2011, 08:28 AM | #16 |
03-26-2011, 05:55 AM | #17 |
this thread is gold.
Getting the tank out of the cab is my first move. Bookmarked. |
03-15-2011, 02:46 PM | #18 |
Does anyone know the Ohm reading between ford and GM?
I plan on using aftermarket gauges and thought it would be easier to use the mustang tank with the appropriate Ohm settings... Anyone know what those Ohm readings are? |
03-15-2011, 03:00 PM | #19 | |
FYI the fuel sender can be read with an ohm meter. The reading when empty is approximently 73 Ohms and when full approx. 10 Ohms. Ford went to a different resistance rating for their fuel senders in the, I believe, early 80s. It is 240 Ohms empty and 33 Ohms full This matches ohm readings if you got to Jegs for fuel gages. They have: 0-30 ohms (our old Chevy Trucks) Last edited by lakeroadster; 03-15-2011 at 03:02 PM. |
03-15-2011, 04:16 PM | #20 | |
Thanks!!! Posted via Mobile Device |
03-15-2011, 04:30 PM | #21 | |
Stick with the Bowtie... much less confusing On one of my previous projects I built a '27 Ford Hot Rod Roadster Pickup. I got a great deal on a $500 '85 Mustang GT that I used for the motor & tranny (5.0HO and 4-speed manual). By the time I was done buying / fabricating all the wierd brackets and pieces parts to make it fit/work I would have been money & time ahead using the tried and true SBC and Muncie combination. Like my signature line states: A smart man learns from his own mistakes, a wise man learns from the mistakes of others. Last edited by lakeroadster; 03-15-2011 at 04:37 PM. |
