406 SB 700R4 NP205 Twin Stick
![]() Join Date: Jul 2009
AGR Performance Super Box 2 rebuild questions
So I would like to convert my 71 K10 4x4 to a crossover steering front axle. I have all the other parts ready to order, but I have recently purchased a 4x4 Super Box 2, which you cannot use for a crossover steering set up, you apparently need a 2wd box.....oh if I had known that when I laid down the $400+ for the box
Restoration Virgin!
Re: AGR Performance Super Box 2 rebuild questions
ttt
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
If it were me I would get the type of crossover steering arms that eliminates the Kinpin Spring on your D60. I would add a hydro setup I would buy PSC Hydro Assist Kit for your year. You will have one finger steering....smooooth.. Then I would clean up that steering box and put it up fer sale on Ebay and pray I get at least half my money back.
![]() I have had to do similar things when changing direction.. I'm perrty sure you can pull out the guts and put in 2x4 guts but I have never done that. Maybe that company makes a 2x4 version and will swap it for you? Good Luck and take pics!! ![]() ![]()
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks ![]() Last edited by Burt4x4; 03-18-2011 at 10:13 AM. |
I have been considering two different options. The first option was to try and rebuild the AGR box, because as it sits right now, I have 1 finger steering without the crossover set up, and running on 37" tires. And then convert it to a crossover set up, with the option of adding hydraulic assist afterwards. I got a rough quote from AGR for what it would cost me for them to do the work, and for changing the shaft and drilling/tapping for hydraulic assist would cost me about $225, without shipping.
The second option was basically what you said, but with going with a Redneck Ram setup, because it would be less expensive. http://westtexasoffroad.homestead.co...osteering.html |
New Member
From what research I've done, it looks like you can just swap out the sector shaft in your 4x4 box with one from a 2x4 box. I have looked into this because I did the same thing as you. Paid good money for a new Redhead steering gear and then decided to go with crossover. I contacted Redhead and they told me I could send the box back to them and they would charge $59 for the new 2wd sector shaft and $50/hr. labor, likely only 1 hour labor needed. I do have a spare 4wd box that I was going to try the swap on myself and see how it works but haven't had time.
