03-17-2011, 01:29 AM | #1 |
Stripped wheel studs
So I have this 83 chevy 4x4 half ton and half the wheel studs are stripped. How the hell did the dip**** strip the wheel studs? How hard are the front ones to replace? Can I do it with the rotors on ?
03-17-2011, 05:25 AM | #2 |
Re: Stripped wheel studs
You have to pull the front hubs off the truck and beat the stud out with a hammer thend flip it over and beat a new one in with a hammer and punch. The studs are what hold the rotor in place.
1949 Five Window, 1973 Step Side, 2000 Z71 |
03-17-2011, 09:35 PM | #3 |
i pulled mine in tight by tightning the nuts with the wheel on
1986 K-10 "ole blue" |
03-19-2011, 06:05 PM | #4 | |
Though it may "technically" work, I would not do it like that. It is not only harder on the stud than need-be, there is a lot of force being applied to the conical seat of the wheel too. A steel wheel is intended to have some "spring" to it, which can be damaged by this. It can also "gall" the nut and/or the wheel. The smaller (7/16") studs of a 4x4 are more likely to be damaged by this method.
If you feel that you "have to" pull them in: Use a flat faced nut (or the back of a conical nut) Use a flat washer under the nut Lubricate the threads and the faces of the washer and nut w/a good hi-pressure grease. It would be far better to press them in from the back side, either by truly "pressing" or with a hammer/punch.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. |
03-19-2011, 04:37 PM | #5 |
Resident of Here
I did the same thing, the lugs got stripped. Get the hub socket from your local auto parts store and diagrams of how everything goes together. You MUST take the front hubs/brakes apart.
~Bradley~ 2004 Black GTO LS2/T56 too much to list Miss having a truck |
