Need some ID help
I ran the following block # into mortec.com and this is the options
3970010....302.....69....4...Z-28 Camaro 3970010....327.....69....2...Trucks and industrial 3970010....350...69-80...2 or 4 How do I know what this is?
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
And this is the casting from the heads
333882.....74-80...350/400......76cc chambers
Hey dubie, by the head number I would say you have the later model 350, but another way to check is by the id number to the left of the water pump in front of the passenger head. This will give you engine code and years of vehicles placed in. Not sure if it will tell you wheather two or four bolt though.
1972 chevy k10 4x4 longbed 4-inch lift, 3.73 front/rears, frame off nearly complete 1972 chevy k10 4x4 longbed parts truck, known as the "ugly green machine" 1990 GMC 3/4 shortbed ext cab Always in need of 67-72 parts in central ks. |
You were at the right site for how to find date codes also.... read on http://www.mortec.com/location.htm
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
