Old 03-17-2011, 07:03 PM   #1
GeorgeLeonard
Thumbs down Upper Shock Mount
It was a nice day today in New Jersey, so I went outside to check out the 1966 I bought over the winter when I was going out of my mind with boredom. What I found was the left front upper shock mount was pulled completely out of the frame and the right one is "cocked"- at least I think its cocked. I attached a picture of the shock mount taken head on so you can see it. Its supposed to be coming straight out of the frame right? What is the best way to fix this? My initial idea was to slip a piece of pipe over it and try to bend it back. But after thinking about it, I decided that would be a dumb thing to do. What do you guys think? Is this a job for a pro with a welder? Any suggestions would be sincerely appreciated.
GeorgeLeonard is offline   Reply With Quote
Old 03-17-2011, 11:26 PM   #2
SCOTI
SCOTI's Avatar
Re: Upper Shock Mount
The shock mounts are angled on the side of the frame (@ least on 63-87's).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 03-18-2011, 12:01 AM   #3
markeb01
Senior Enthusiast
markeb01's Avatar
CPP offers this reinforcing kit which may prove helpful:
http://www.classicperform.com/Instru...F/6372FSRB.pdf
I know someone makes a new bracket that’s much stronger and uses the original hole to locate a new mounting plate, but I can’t find a link at the moment.
Old 03-18-2011, 08:46 AM   #4
GeorgeLeonard
So the upper shock mounts are supposed to be angled coming out of the frame? Im glad I didnt try to straighten it out then. I already ordered two new mounting bolts and reinforcing brackets from CPP but now Im wondering how the reinforcing brackets will work with an angled shock bolt?
Looks as if my bigger problem is going to be what to do with the other side which has been ripped out completely so that all that is left in an oblong hole. How critical will it be to duplicate the angle that the shock mount is supposed to make coming out of the frame?
Does anyone think it might be a good idea to put air bags in between the front coil springs and skip the shocks altogether? I dont have any experience with bagging. Does one still use shocks if you have air bags? I know people use air bags to raise and lower their vehicles but I dont want to do that. Standard height would be just fine with me. If they are a valid alternative, what would be a good source for them? I looked around a little but couldnt find anything to fit 1966 Chevrolet C10 swb stepper.
Old 03-18-2011, 08:51 AM   #5
GeorgeLeonard
Just looking at the picture provided by CPP and linked by markeb01. It looks as if the angle is already accounted for in the construction of it. So it seems Ill be alright with the right shock mount. Now, what to do with the left?
Old 03-18-2011, 08:58 AM   #6
lakeroadster
George,
You still need shocks if you use air bags. Air bags is really a slang term. Air springs is the correct engineering term.
As for the postioning of the ripped out upper mount, can you get to the back side of the frame? If so you could make a fixture using the "good upper bracket" and lower shock mount that simluates a shock, basically (3) pieces of pipe tack welded together. Then use that fixture to locate the upper mount on the other side.
Make sense?
John
lakeroadster is offline   Reply With Quote
Old 03-18-2011, 09:25 PM   #7
GeorgeLeonard
This is a pic of the left side. Nice, huh? I think Im screwed.
Old 03-18-2011, 11:30 PM   #8
markeb01
Senior Enthusiast
markeb01's Avatar
I went back and watched the taped episodes of Trucks TV where they built a 1966 C10. The front suspension they used was the Strong Arm System from Air Ride Technologies. The kit eliminated the original front upper shock mounting stud. It is replaced with an adapter plate that bolts to the frame and requires the use of a shock with a stud style upper mount. It looks tremendously strong.
Unfortunately they don’t show the adapter bracket anywhere on their website that I can find, so I’m not sure if it is still being produced. The piece I’m talking about can be seen on the recently released DVD:
http://www.powerblockswag.com/Trucks...hevyc10dvd.htm
It can also be watched online at Amazon for $1.99 per episode. It may be in this episode, but the preview isn’t long enough to tell. It was in the segment after the frame came back from powder coating. As I said, it could be this episode but I’m not sure:
Amazon.com: Trucks!: Season 2007, Episode 16... Amazon.com: Trucks!: Season 2007, Episode 16...
It might be worth calling Ridetech and asking if the style bracket used in the DVD is still available as a separate item, and also confirm if it will work with an original suspension.
http://www.ridetech.com/
If it’s no longer offered, it shouldn’t be too difficult to replicate if you have welding skills, if you can at least see what their adapter looked like.
Old 03-19-2011, 10:13 AM   #9
GeorgeLeonard
Smile Re: Upper Shock Mount
Thanks Markeb01 for this great reply. I will certainly look into your suggestions. I really appreciate you taking the time to research this as you did. This kind of assistance is hard to come by. I am sincerely grateful for your answer.
Old 03-20-2011, 09:39 AM   #10
SCOTI
SCOTI's Avatar
POL also offers a front shock relocating bracket for the top of the frame. This might fit your needs as well....
http://www.performanceonline.com/196...-KIT-FSMK6372/
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-20-2011, 10:06 AM   #11
GeorgeLeonard
That looks good too. Do you think I would need a different and longer shock for this? I guess it goes without saying that I should do this to both sides even though one of my sides is okay as is?
Old 03-20-2011, 10:18 AM   #12
SCOTI
SCOTI's Avatar
Definitely do both sides for consistency. As for shock length, is the truck altered in any manner (lowered @ all; notable spring sag)?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-21-2011, 09:50 AM   #13
GeorgeLeonard
So that clutch linkage is bolted on and not riveted on? Ill have to check that out. If its riveted on, Im going to start throwing things! It may be a few days before I can get out there. This is what I woke up to this morning. Thanks for the suggestion. Ill get back to you.
Old 03-21-2011, 10:26 AM   #14
SCOTI
SCOTI's Avatar
It's riveted.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-21-2011, 01:56 PM   #15
GeorgeLeonard
Unhappy Re: Upper Shock Mount
So many things on this truck are easy. Just this one thing seems to want to bite me in the ass every chance it gets. It may be time to go to an auto body shop and let them solve this problem. I was trying to get away cheap but it looks as if that ship is getting ready to sail.
Old 03-21-2011, 02:31 PM   #16
SCOTI
SCOTI's Avatar
Maybe find a board member cutting up a frame & see if you can purchase a 'patch panel' for the shock stud area. Cut out the old messed up opening & have the patch piece welded in.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-21-2011, 03:03 PM   #17
Heater63
Heater63's Avatar
George,
Excellent advice from everyone above ^^^^.
I had the same problem on my '63, the upper attach bolt had torn through. The cheap fix is simple. Get the grade 8 washer that fits the shock bolt, I don't remember which size it is, but its a perfect fit, and weld it onto the frame. Then use the CPP upper shock reinforcing kit and you will be good for another 40 years. The kit Scoti showed us would be the best, but also the most $. Hey, at least you have options to pick from now!!
292 + TKO500
Heater63 is offline   Reply With Quote
