03-18-2011, 03:56 PM | #1 |
have an oil leak...valve cover
85 gmc.
350. have oil leak by valve cover. i was gonna change it a while back but was not sure if/or how i was suppososed to remove some canester looking thing. anyway, think im gonna try tomorrow afer work. question i have is, is there anything i can use to clean up the area before i swap gaskets? something i can use to get the oil, muck, etc off. that way when i change the gaskets i dont have to have a mess there. thanks for any advice... pic of canester thing i was talking about. |
03-18-2011, 04:34 PM | #2 |
78K & 79C Jimmys
Re: have an oil leak...valve cover
egr valve?that won't have to come out
engine shampoo,pressure wash,cover the carb etc you can use engine shampoo to wash the covers inside and out(once they are off,then dry) but i have just used gas but a varsol would be good too when you have them out make sure the bottom is flat before they go back in bottom being where the gasket goes(they warp most need to be straightened out prior to reusing or they leak again) it's normal
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
03-18-2011, 05:01 PM | #3 |
thanks for reply.
guess thats egr. didnt know that. so ill be able to just unbolt and pull that cover off? i dont have a pressure washer. was wondering if i could put some simple green or something to remove the oily mess. what warps. the covers? i was afraid, that after i change gaskets, if i still have leak that something else is warped. hope not. not sure if valve cover sits on heads or not. but hoping its just a bad gasket, not warped heads. or other problem. hopefully ok. motor is not stock from 85. changed at some point. |
03-18-2011, 05:18 PM | #4 |
78K & 79C Jimmys
yes just the bolts and may need some slight prying(baked gasket)
but they usally come loose from where they are leaking first more or less straight up and out yes the covers warp(a lot of ppl don't know to fix this when they are out) warped heads = anti freeze is found some where it shouldn't be (like the tail pipe lol) just a bucket and scrape or brush the gunk off i imagine a brake cleaner spray would do it too varsol or gas,slight rub of fine sand paper (covers)will help clean the seal can't think of the name of it but i use a silicone to hold it on the cover
03-18-2011, 05:22 PM | #5 |
buy a can of engine degreeser, ride over to the local car wash, getting the engine good and warm, spray the degreeser on, wait 10 mins and pressure wash it off. I usually leave my truck runnin while I'm washing the motor, and I dont spray directly into the carb or distributor, but if your scared you can cover it up with a plastic bag.
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
03-18-2011, 05:49 PM | #6 |
ok guys. thanks for info.
maybe ill pic up some cleaner with the gaskets tomorrow and from the parts store, head to car wash. eventually ill want to change valve covers, intake, carb etc. but dont have the big bucks. so little by little. figure if i can stop the leak now, and clean it up a bit, ill be a bit better off. |
03-18-2011, 09:36 PM | #7 |
For what it's worth, I had to change my valve cover gaskets last summer. Go with Felpro brand gaskets and I ended up removing the EGR valve to make things easier getting the valve cover off/on....In the end, it's so nice to sit at stop lights without people looking at my truck with the oil smoke coming from the exhaust manifolds...okay sometimes I even laughed wondering what they were thinking...good luck!
_______________________________________________ 1985 Chevy Scottsdale K20 350 with 700R4 running 3.42 gearing aka "The Honey Badger" 1993 Silverado C3500 Ext. Cab Dually 6.5 turbo diesel |
03-18-2011, 10:59 PM | #8 |
LOL I felt the same way before I changed the valve covers on my 76
<Brandon> 1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works. 1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15 81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in 1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096 1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195 |
03-20-2011, 08:52 AM | #9 |
well i changed the gaskets yesterday. i thought i told the lady at part store i wanted rubber ones.. she gave me cork ones..
before changing them. id didnt have the smoke like you guys had. just remember the idiot who did my exhaust tell me i had a bad leak there. so i was able to get the valve cover off. the one on the left. had to work it a bit to get out but i got it. mighta bent it a bit going back in. not sure tho. after install, i started truck and had a good bit of smoking from driver side. and a bit later the passenger side started smoking some. took it for a ride to get some much needed gas. and i didnt see any more smoke. ill got out in a bit and see how it looks. took a couple pics. what do the numbers mean?? just basic stock stuff im sure. |
03-20-2011, 09:49 AM | #10 |
Nice work. Regarding the initial smoking after gasket replacement, I would not worry as you probably had some oil get on the manifolds while replacing the gaskets. Mine smoked for a day as the bits of old gasket material/oil burned off the exhaust. The numbers on the heads are the specs for the valve size, chamber size, etc. You can look them up on line or someone here may be able to translate for the specs
03-20-2011, 09:53 AM | #11 |
thanks for reply. i kinda thought it may have been some run off that needed to burn off. or some of the cleaners i used burning up.
hopefully it wont end up leaking. that would suck. im kinda hoping the passenger side dont give me any problems. i had to ruff it to get in. maybe should have take the egr valve off to make it easier. well hopefully all is well. thanks again guys. |
03-20-2011, 09:08 PM | #12 |
BAD BOW-Silverado XST
Yes, get the wide aftermarket clamp downs. They are available at parts stores.
09-03-2011, 09:14 PM | #13 |
Master Hater
doesn't matter the covers will be leaking in 6 months again anyway, I hate perimeter bolt valve covers
1997 C1500 ECSB 4.3/NV3500 8.5 3.42 "This evening, all of you bleeding hearts... why don't just go ahead and hug yourself for the next 20 minutes or so, because there's a really good chance you're gonna be offended".- Captain Owen Honors |
09-03-2011, 11:19 PM | #14 |
6.0 powered square
I never had that problem and I had the cheap chrome valve covers with the t bar fasteners
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
09-04-2011, 10:01 AM | #15 | ||
I am a believer in gluing the gaskets to the valve cover with an adhesive like Gaskacich, or even contact cement, silicone will just split the gasket. Stick them on and let it dry thoroughly, well before you are ready to re-install them. Use the "spreaders" under the bolts and go easy with tightening them, more is not better. I did them like this for years with race cars that needed frequent valve adjustments and on daily drivers that were essentially ignored. The covers come right off with-out sticking to the heads, and the same ones go right back on. They should barely have a dent where they touched the heads, but still be sure to put them back onto the same side. Over-tightening is the biggest problem with these
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. |
09-04-2011, 10:40 AM | #16 |
I have used both cork and rubber gaskets. I like rubber better. The rubber gaskets will leak after about 5,000 miles, but you can carefully tighten them and they will seal again. The important thing is to get the best quality gaskets you can buy. I also use sealant on the valve covers. It seems that every kind of gasket I install will leak if I don't use some kind of sealant.
For cleaning, I just spray a little engine degreaser on the covers first, then wipe it off with old cloths. When the valve covers are off the engine I use gasoline on the underside, and more engine degreaser on the top and bolts/washers. |
09-04-2011, 12:08 PM | #17 |
I also use a similar method.... Adhere the gasket to the v.cover w/RTV sealant or adhesive (I like the spray-on Copper gasket sealer). Let it tack up & attach the gasket to the cover. Let that set-up before final installation.
I like using the FelPro gaskets w/the crush rings that help prevent over-tightening (which leads to pre-mature failure & leakage).
09-06-2011, 09:10 AM | #18 |
78K & 79C Jimmys
i'll be doing some this week on the 79
bucket and thinner to clean final wash/scrub with dish soap before painting spreaders for sure my other jimmy didn't have them and leaked bad.... the thin stamped covers just warped instead of sealing even when straightened out(prob the most important part, often over looked)
