Old 03-19-2011, 05:54 PM   #1
Stricklinator
Stricklinator's Avatar
Cluster Removal Question
I want to take out my gages to fix some burned out bulbs and try and diagnose my non-working fuel gage. I was wondering how the headlight and wiper switches come out? They seem to be holding in the bezel. It looks like the switches have a trim piece that screws in holding the bezel in, but I don't know how the knobs come off. Thanks in advance for the help!
Stricklinator is offline   Reply With Quote
Old 03-19-2011, 05:59 PM   #2
eightbanger
454 MAKES IT ROAR
eightbanger's Avatar
Re: Cluster Removal Question
Wiper knob has a small screw at the base, the headlight switch has a small button to push in to release it you will access that by reaching up under your dash feel around the back of the swithch till you find it.
Nigel.
An American living in a British body.
1971 Chevy Cheyenne 10 454
"In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell
"When injustice becomes law, resistance becomes duty" - Thomas Jefferson
No more pain.
03.12.60 -- 12.28.10
http://www.youtube.com/Eightbanger
eightbanger is offline   Reply With Quote
Old 03-19-2011, 06:13 PM   #3
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Yeah Wiper knob has a very small screw on it
Lights have a small button at the top of the switch, you'll have to push in button and wiggle/pull on switch.
John
1999 Toyota Tacoma 4x4
Old 03-19-2011, 07:02 PM   #4
Stricklinator
Thanks you guys, I got them off easy with your info. The oil pressure line is another story though...
Old 03-19-2011, 07:07 PM   #5
oldblue1968chevy
cut da sum beech lol
Nah, I dunno maybe let it soak in PB blaster overnight, with some heat tomorow? lol
John
Old 03-19-2011, 07:16 PM   #6
eagleuh1
eagleuh1's Avatar
It should come off pretty easy, its a little tiny brass tubing nut. Use a tube nut wrench to keep from stripping it if you have one. Did you check to make sure the wire for the fuel guage is plugged into the fuse box. It won't work without it. I kept kicking mine out is how I know. Good luck.
eagleuh1 is offline   Reply With Quote
Old 03-19-2011, 09:28 PM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
it takes more effort to remove the panel than it does to replace the bulbs with it installed. You can also see most of the circuit on the back side too.
Whats the fuel guage do? Most of those isses end up being either a bad float or a damaged wire from the tank.
Old 03-19-2011, 11:39 PM   #8
Stricklinator
I got the bulbs changed without disconnecting the oil pressure line. The gas gauge hasn't worked since I got the truck in January. The wire seems to be connected from tank to fuse panel, but I get nothing. I have a new sender on back order from Summit, but I wanted to see if the gauge could be disconnected or something.
Old 03-20-2011, 01:17 AM   #9
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Have a look.
http://www.6066gmcguy.org/Electrical-02.htm
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 04-19-2011, 02:43 PM   #10
Cbrown67
how about the choke knob how does that come off?
Cbrown67 is offline   Reply With Quote
Old 04-19-2011, 02:48 PM   #11
Longhorn Man
there is no stock chrome knob... what does it do?
Old 04-19-2011, 03:08 PM   #12
Cbrown67
the Choke knob on the right side of the cluster is what i'm trying to figure it it pulls out there is no screw on the the knob it self
Old 04-19-2011, 03:15 PM   #13
Cbrown67
also behind every knob there is a nut that is threaded towards the Dash much you remove those as well?
Old 04-19-2011, 09:02 PM   #14
Putter
More Cowbell....
Putter's Avatar
Gas gauge reading way past full = open circuit
Gas gauge reading below empty = grounded circuit
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket
Putter is offline   Reply With Quote
Old 04-19-2011, 09:07 PM   #15
treveiger
treveiger's Avatar
saving this
1969 Chevy c20(Miss Hackjob)
treveiger is offline   Reply With Quote
