rad mounts different?
I have a 3 core red now. I know the 4 core are thicker. Are the mounts different or just the thickness of the rubber that is between the mount and the rad? This is in my 1 ton crew cab
Thanks Last edited by 72jimmy4x4; 03-19-2011 at 06:47 PM. |
Re: rad mounts different?
anyone?
depends on the tanks on the rad. some 3 cores had 4 core tanks. Best bet is to measure the the 3 core and compare to the specs of the 4 core.
![]() ![]() ![]() 67 c10 swb build in progress 70 c10 lwb driver pending parts for drastic overhaul 70 c20 lwb parts truck for above mentioned drastic overhaul 71 k20 lwb building for off road use and towing |
If you have a 3 core and it uses two small brackets on the ends then you have the small tanks. If you are putting a standard 4 core in you will need a completely different bracket and most likely a different shroud. The bracket on a standard 4 core goes all the way across the radiator.
Posted via Mobile Device |
