Old 03-19-2011, 11:38 PM   #1
motiveauto
motiveauto's Avatar
73-87 Front Suspension Swap Question
OK Guys Ive got another question: Im swapping in the front crossmember and suspension from a 84 C10 into my 65 C10. I dont want power steering and I dont want power brakes.
-Can I use the 65 steering box with the 84 pitman arm?
-Any suggestions on a manual, dual master cylinder?
86 K20 6" lift
66 C10 LS2 T56
1947 Ford Rat Rod
Softail Deluxe
Softail Chopper
motiveauto is offline   Reply With Quote
Old 03-19-2011, 11:48 PM   #2
protrash64
Resistance is Futile
protrash64's Avatar
Re: 73-87 Front Suspension Swap Question
For the ms/cyl, you can get a stock one for early 70's(?) trucks and get a prop valve anywhere from junk yard or new aftermarket. I bought a kit from POL and just got this one going; there are cheaper ways to do this, however.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 03-19-2011, 11:50 PM   #3
nachodog2
Hell yeah!!!
nachodog2's Avatar
Not completely sure on the steering box( someone will let you know for sure) as far as the master, i'm running a '72 corvette manual disc brake one, just bend up some new lines to split the system and your good to go. I din't even need to adjust the pushrod.
Stock is good but custom is the sh*t!
nachodog2 is offline   Reply With Quote
Old 03-20-2011, 12:04 AM   #4
motiveauto
motiveauto's Avatar
Thanks alot guys!
86 K20 6" lift
66 C10 LS2 T56
1947 Ford Rat Rod
Softail Deluxe
Softail Chopper
Old 03-20-2011, 12:13 AM   #5
protrash64
protrash64's Avatar
I think the one nacho is using is what I have pictured. I went this route as I was in a hurry to get the parts.
Old 03-20-2011, 01:08 AM   #6
Captainfab
60-66 Nut
I believe you can use the original '65 pitman arm on the '84 draglink.
Old 03-20-2011, 08:41 PM   #7
motiveauto
motiveauto's Avatar
Im going to assume that ill be able to use the idler arm bracket too?
86 K20 6" lift
66 C10 LS2 T56
1947 Ford Rat Rod
Softail Deluxe
Softail Chopper
Old 03-20-2011, 09:41 PM   #8
protrash64
protrash64's Avatar
You could also get the adapter sleeves with 2 thread sizes to go from the newer tie rods to the older centerlink. Saves messing with all of the 'middle'.
Old 03-21-2011, 01:36 AM   #9
Captainfab
60-66 Nut
I'm thinking you'll have to use the idler arm from the '84 since you're using the '84 draglink. To use the later model idler arm you will have to locate it in the correct position, and drill 2 new holes. I don't have much experience in mixing and matching steering linkages, I always switch over to the later model steering linkages. It just makes things simpler and easier to remember what you need when it comes time to replace parts.
