Old 03-20-2011, 03:43 PM   #1
1966Stepside
1966Stepside's Avatar
LS swap fuel system setup
In the next week or so, i'm going to begin swapping a 4.8/4l60e into my '66 Stepside. I'd like to hear from folks who have done one of these lsx swaps and moved their fuel tank to the bed. I've done quite a bit of reading on the subject, but there are a couple parts I'm not clear on.
I don't mind having the fuel pump external to the tank, but what I dont' want is to have to have a fuel filler door in the middle of the nice wooden bed I plan to eventually install. Are there any aftermarket tanks that have a side fuel filler neck, or that leave enough room between the tank and the bed to put a 90 degree bend at the neck and run the filler from the rear fender area? I've also read that the tank needs to be baffled internally, but is that for internal fuel pumps only?
I'd love to see pics if you've got em!
Photobucket is messing with me, but here's a couple of shots of my truck when I brought it home.
Thanks!
1966Stepside is offline   Reply With Quote
Old 03-20-2011, 04:01 PM   #2
rbar
rbar's Avatar
Re: LS swap fuel system setup
You might consider one of those set ups where the fuel filler is below the wood and one board hinges up to allow access.
1963 Chevy stepside 327
1965 Chevy swb 383
1996 Mystic Mustang Cobra
2009 Pontiac G8 GXP 415hp/415tq 6speed
rbar is offline   Reply With Quote
Old 03-20-2011, 06:49 PM   #3
TR65
TR65's Avatar
66,
Here is how I did mine.
http://67-72chevytrucks.com/vboard/s...d.php?t=334077
TR
1965 C10 SWB Fleet
Two owner
LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880
TR65 is offline   Reply With Quote
Old 03-20-2011, 07:52 PM   #4
1966Stepside
Originally Posted by TR65 View Post
I like what you did there. I was browsing summit for the RCI tank you used, but I don't see one with that filler snout coming out at a 90 degree angle like that. Is that something you fabbed up yourself?
Old 03-20-2011, 08:25 PM   #5
TR65
TR65's Avatar
66,
Thanks. This is it.
http://www.summitracing.com/parts/RC...5&autoview=sku
TR
1965 C10 SWB Fleet
Two owner
Old 03-20-2011, 08:34 PM   #6
1966Stepside
TR65,
I was really looking for the fuel cell you were using. Was that a summit part also, or did that come from somewhere else?
Old 03-21-2011, 01:43 AM   #7
Captainfab
60-66 Nut
Another option is a fuel tank made specifically to your needs. Check out this vendor's thread....
http://67-72chevytrucks.com/vboard/s...d.php?t=362307
and this vendor also....
http://67-72chevytrucks.com/vboard/s...d.php?t=446688
Old 03-21-2011, 09:03 PM   #8
TR65
TR65's Avatar
Originally Posted by 1966Stepside View Post
TR65,
66,
I used a Rick's tank like jays68yak.
They are very nice. They even put in two sending units for me, one for the computer and one for the old gas gage. The in tank pump is nicely baffled and uses a standard AC delco pump.
TR
1965 C10 SWB Fleet
Two owner
Old 03-23-2011, 10:42 AM   #9
1966Stepside
Anyone got info on non baffled tanks and external electric pumps? Hoping for some good info so i dont waste money on the wrong tank
Old 03-23-2011, 12:12 PM   #10
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I don't think it has to be baffled but it would need to be sumped (pickup at point lowest to tank) so there is a constant supply of fuel to the pickup.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 03-23-2011, 12:20 PM   #11
1966Stepside
Sweet... Thats what i figured, nice to have confirmation
Old 03-23-2011, 01:35 PM   #12
Clyde65
Clyde65's Avatar
I have one of the "fuel Cells" that summit sells, 16gal, it pulls from the lowest point in the front, has no baffles and I havent had any issues so far with fuel starvation.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 03-23-2011, 04:20 PM   #13
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I also run the "fuel foam" in my tank to help with any sloshing that might occur. Works pretty well and its cheap.
Old 03-24-2011, 01:12 PM   #14
1966Stepside
Thanks for the help everyone! Since i had unused gift cards to lmc, i ordered their under bed kit. I'll post pics when i get it installed.
