Badass
th350 leak
when my truck sits it leaks atf. but not so much when its running and under pressure ? anyways . looks like from the lock up switch for the trrouqeconvertteer lock up. witch us un-hooked. any ideas? the shifter seal is new. and the pan gasket is new
84 th350C
Think outside the box? -84c10 (1stcar)→My Build← ![]() -00 Saturn 5spd drop a gear and disappear! 1/4:13:90
Garage wrench
Re: th350 leak
could be tailshaft seal, maybe speedo cable/gear area....??
-Adam 90 V1500 GMC Suburban 350/700R4/NP241..... 01 Saturn SL1 stock DD..... Last edited by SBTork; 03-21-2011 at 08:59 PM. |
Re: th350 leak
i know mine will leak outta the tail shaft if she sits for a while
Lindsey Rae 85' chevy long box, built by a girl! My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=429956 |
Badass
Re: th350 leak
found the leak. its the lock up plug up the drivers side. anyone know where i can get a new plug? even know im not hooking itup. just to hold fluid from coming out of the thing
Insert Witty Text Here
Re: th350 leak
I replaced mine 6 or 8 years ago. I bought it locally from a place that most of the transmission shops buy from. I looked on bulkpart.com, but couldn't find it. I have never dealt with them, but have seen others recommend them.
Slonaker |
Re: th350 leak
vent is on driver side toward the top...reach up there and see if fluid is coming down the side from top.
Badass
Re: th350 leak
nope not there. its the plug. i drained the fluid and cleaned the area and put rtv all around it. going to add atf tomorrow and see if it leaks
| Bookmarks |
