VA72C10
![]() Join Date: Mar 2008
How to identify column wiring?
Here are pics of some column wiring I have. Trying to identify if it goes in a std column, tilt, 4spd or auto....etc....anyone have a way to tell?
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
its all about the +6 inches
Re: How to identify column wiring?
standard non tilt column.
Tilt would have a light on it with an added grey wire |
#3 | |
VA72C10
In the first picture of the switch there is a socket attached to the switch which makes the switch one that is used in a tilt column.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
VA72C10
Is that where the bulb would mount?
On that note where does the grey light wire plug into?
Jim! GREAT EYE!
I looked for the wire and saw nothing! Jim is 100% right, that is a bulb holder, it is for a tilt. On the other question on where to plug the wire for the light, it plugs into the fuse block, on the terminal labled cluster feed. This will control the light with the dash lights. |
VA72C10
So am I still missing the grey wire then? And where to find that bulb? I'll check my factory assembly manual to see if I can find out in there.
Is there a difference between 4spd and auto columns on the wiring?
I'm not 100% positive, but I highly doubt there is though.
![]() Join Date: Apr 2010
I don't know what that wiring harness goes to but it is not for a factory tilt column
VA72C10
The plot thickens....
![]() anyone that has taken these apart recently and has some pics that can verify what this may be from? Thanks!
That's not from a 67-72 truck column. Looks like either 66 or older truck or possibly a 68 or older car, Impala, Camaro ext.
Posted via Mobile Device |
VA72C10
Anyone that can verify that? I'm cornfused
#15 |
TILT COLUMN GURU
![]() Join Date: Dec 2006
Yes definitely not a 67-72 Looks to be 64-66 truck.
kevs_classics64 64 Impala SS Conv 72 Blazer 2wd 75 Jimmy 2wd 63 Belair wagon 02 Silverado ext cab. DD RIP EL JAY |
