03-24-2011, 10:41 AM | #1 |
c notch strength
after installing a notch, properlly, is the section behind the notch as strong and supported as it was before hand?
im building a custom trailer for myself. i have designed a air ride suspension, but it would require a notched frame for the best result as far as lowering it. making loading and unloading a breeze for those frame scrapers! help guys, ideas, thoughts, suggestions? |
03-24-2011, 12:02 PM | #2 |
Re: c notch strength
I think if towing it be an issue
but c notch on the trailor to drop it.. the bed load is spread out |
03-24-2011, 01:09 PM | #3 |
put your air bags directly over the rearend...i have found in my recent experience that if your towing a load or hauling heavy things that airbags does great over the rearend then compaired to on the link bars
03-24-2011, 01:55 PM | #4 |
C-notching the frame weakens the frame unless you maintain the original height of the frame above the notched area.The overall strength is in the height of the frame rail.
Boxing the inside of the rail or plating the outside will help restore some strength but it will not return it to what it was originally rated. Good reading here.... http://67-72chevytrucks.com/vboard/s...d.php?t=393867
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 03-24-2011 at 01:56 PM. |
