Old 03-25-2011, 08:13 PM   #1
one low c10
junkyard score
picked up a mint dash pad out of a 78 scottsdale today for $35! not a flaw on it. not sure if itll fit my 84 but it was too good of a deal to pass up. going back to get the seat it looks brand new too. woo hoo!
one low c10 is offline   Reply With Quote
Old 03-25-2011, 08:22 PM   #2
sixshooter798
Desert Rat
sixshooter798's Avatar
Re: junkyard score
The gauge bezel isn't going to fit, and the headlight switches may or may not line up.
sixshooter798 is offline   Reply With Quote
Old 03-25-2011, 08:29 PM   #3
one low c10
Re: junkyard score
so i cant use my 84 bezel? should i get the bezel out of the 78? the pad will interfere with the switch? i know the pad is more rounded and notched around the bezel insted of straight but it looked like it would work. if not oh well maybe someone on here could use it
Old 03-25-2011, 08:38 PM   #4
franky69c10
chevy runs deep
franky69c10's Avatar
Re: junkyard score
Pics or it didn't happen
RAIDER NATION
1969 c10 swb soon 2 b on the road...
My LWB is a SWB now
http://67-72chevytrucks.com/vboard/s...d.php?t=498241
franky69c10 is offline   Reply With Quote
Old 03-25-2011, 08:39 PM   #5
lilpoindexter
lilpoindexter's Avatar
Re: junkyard score
lilpoindexter is offline   Reply With Quote
Old 03-25-2011, 08:47 PM   #6
one low c10
Re: junkyard score
ok ok lol let me go down to the basement, will have some pics in a few
Old 03-25-2011, 09:01 PM   #7
one low c10
Re: junkyard score
here ya go!
Old 03-25-2011, 09:05 PM   #8
Nodak mack
Nodak mack's Avatar
Re: junkyard score
ohh wow. that is nice .. hummm to bad im shipping off to the sandbox in a few weeks othewise id say send it over. i got a 77 with one bummed up dash.
1977 C-10 chevy silverado long box 454 th400
1969 Chevelle 4 door hard top 350LT 2 speed Powerglide
1955 Oldsmobile 88 hardtop Rocket 324 turbo hydromatic
bowtie or die.
Nodak mack is offline   Reply With Quote
Old 03-25-2011, 09:08 PM   #9
one low c10
Re: junkyard score
there was another one there off an 86 had one little crack on the right side in the speakers holes. it was just cracked between 2 of the holes might go get that one too, had a perfect bench seat too.
Old 03-25-2011, 09:49 PM   #10
Pop's C-10
Pop's C-10's Avatar
Re: junkyard score
That is a nice score..
Pop's C-10 is offline   Reply With Quote
Old 03-25-2011, 10:58 PM   #11
FritzA
Re: junkyard score
Dang,
Like Nodak Mack said that would look good in my 77 too! Even the right color.
Nice score!!!!!!
FritzA is offline   Reply With Quote
Old 03-25-2011, 11:21 PM   #12
jitteryguy
GoatLube Experss
jitteryguy's Avatar
Re: junkyard score
curious to see how it fit's, I'm think'n of go'n to that style dash in my '87. wish I could find a deal like that .
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn.
'87 R30 dually 454/TH400
'85 1/2 ton CCSB
'92 S10 350/350
'84 MonteCarlo 383/PG/9"ford
'78 Malibu wagon 350/350
'78 Cutlass (project family car)
'96 S10 Jimmy (Moma's)
jitteryguy is offline   Reply With Quote
Old 03-26-2011, 04:32 AM   #13
sixshooter798
Desert Rat
Re: junkyard score
My buddy and I swapped a 78 dash pad into his 86 Blazer.
The instrument clusters are different, so if the one attached to that awesome dash pad is still there, grab it. Don't forget the small piece that goes under the steering wheel, cuz that is different too.
His Blazer had the windshield wiper switch on the column, not the dash. Therefore, the headlight switch is centered over there, not up above the wiper switch. If yours is the same way, you'll have to move the headlight switch up. The headlight switch sort of screws into the metal behind the bezel, and it should be pretty clear where it would be if a wiper switch were on the dash. Drill a hole in the metal on the dash, and move the switch up. If you can't figure out where it should go, take it off and install the dash and bezel normally. Then take a sharpie and mark where the headlight switch needs to go. Unassemble, and drill a hole where your mark is.
Only bad part is now you will have an empty hole where the windshield wiper switch would have gone on the 78 bezel. Since my buddy had installed off-road lights on his bumper at the same time, it was the perfect spot to put a toggle switch for the off-road lights. If nothing else, you'll have to fab up something to cover the hole.
Hope that clears it up!
Old 03-26-2011, 05:53 AM   #14
BigBlocksRule
Re: junkyard score
When did GM move the VIN? Later dashes have the cutout at the front edge of the windshield, earlier were straight since the VIN is on the door post instead of the dash.
BigBlocksRule is offline   Reply With Quote
Old 03-26-2011, 06:19 AM   #15
Prong
Re: junkyard score
Originally Posted by bigblocksrule View Post
when did gm move the vin? Later dashes have the cutout at the front edge of the windshield, earlier were straight since the vin is on the door post instead of the dash.
1979.
Prong is offline   Reply With Quote
Old 03-26-2011, 07:46 AM   #16
BigBlocksRule
Re: junkyard score
So you'll have to make a cut-out for your VIN, the '78 is straight across the front.
