Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 03-25-2011, 11:23 PM   #1
McNutty
McNutty's Avatar
Chevelle Trick springs ??
I know I have read somewhere someone used chevelle moroso trick springs for the 73 and up trucks! I need to get new springs and new stock ones are 140 bucks! Trick springs for chevelle is around 125!
So anyone know if they will work? Next will be to figure out what spring rate etc to get!
McNutty is offline   Reply With Quote
Old 03-27-2011, 06:34 PM   #2
1970C10truck
1970C10truck's Avatar
Re: Chevelle Trick springs ??
If the springs are the same diameter they should fit. The only thing is the height. I ordered a set of afco springs a few years ago and ended up having to use a set of adjustable spring pockets to close the gap and get the ride height I needed.
1970 C10 swb 350 4spd under construction
1970C10truck is offline   Reply With Quote
Old 04-11-2011, 02:58 PM   #3
kpeztruck
kpeztruck's Avatar
Yes, I used them on mine before changing to a complete custom suspension. You will need to know front weight, to order the proper spring rate. There is a reason that they say not to drive on the street with them. They store so much energy, that I had to tighten the extension on my front shocks to drive without getting a rediculous amount of front end rise. Work well for a cheap way to get weight transfer. Paul Baxter
kpeztruck is offline   Reply With Quote
Old 04-11-2011, 07:48 PM   #4
Super73
Super73's Avatar
Paul,
I have similar issues with the Jeep Grand Cherokee V8 spring I run. 17 7/8" long and 180lb rate by my math (knowing front end weight and unsprung weight). If the fronts are in the tightest setting, cool, not a ton of lift when I get on it, but man, set it all the way loose and I definately max out the front suspension on the street with no burn out.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 04-12-2011, 09:33 PM   #5
68 C-10 KID
Mean Green
68 C-10 KID's Avatar
McNutty,
I have a set of the moroso trick springs for sale if your interested.
They are the 47140 part number.
427 SBC 683HP & 590ftlbsTRQ @ fly wheel.
60'-1.38 1/4-10.43 MPH-124.6
New ET current 4/2019
AKA MEAN GREEN.
68 C-10 KID is offline   Reply With Quote
Old 04-15-2011, 12:27 AM   #6
McNutty
McNutty's Avatar
C-10 Kid sent you a PM !!
