03-27-2011, 08:25 AM | #1 |
Installed 700r4 but it has an electronic speedo connection.
I can already feel the cost coming but can anybody explain my options. I am trying to avoid a GPS speedo. Originally I had a powerglide with a mechnical speedo cable.
03-27-2011, 08:34 AM | #2 |
its all about the +6 inches
Re: Installed 700r4 but it has an electronic speedo connection.
go junkyarding (or e bay or to a trans shop that specalizes in this stuff like bowtieoverdrives.com) and get a tailshaft for a 700 with provisions for a mechanical speedo, then do the math to figure what gears you need.
03-27-2011, 08:41 AM | #3 |
Dave's not here, man
Found this over on the HAMB.
http://www.jalopyjournal.com/forum/s...d.php?t=458768 Hope this helps...
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 |
03-27-2011, 08:54 AM | #4 |
All you need to do is remove the tail housing and you will see a reluctor ring where the speedo cable goes. Remove the ring and you will be ready to install a speedo gear. The speed sensor comes out out of the tail housing and you can install a speedo drive in its place. You need to make sure the speedo drive, and gears all match. There are diffrent offsets in the speedo drives for the diffrent gear raitos.
03-27-2011, 09:01 AM | #5 |
Thanks guys.
03-27-2011, 09:31 AM | #6 |
The Older Generation
Here is a good resource for speedo info... http://www.transmissioncenter.net/sp...n_______va.htm A lot of information there. Speedhut has regular electronic speedometers on sale right now. They have a selector on the individual gauge pages so you can choose which style and colors you want. You can even have your own logo put on the dial. http://www.speedhut.com/gauge_produc...peedometer.htm LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 03-27-2011 at 09:51 AM. |
03-27-2011, 09:35 AM | #7 |
Thank you, that kind of info is what i needed. Can I do this though if the tranny is already installed?
03-27-2011, 09:47 AM | #8 | |
The reluctor ring may be hard to remove from under the truck. Have a dremel or cutoff tool ready. Gary
Gary 1971 Chevrolet C/10 1951 GMC 100 1977 GMC C15 1955 Chevrolet 3100 |
03-27-2011, 09:49 AM | #9 |
Awesome thanks!
03-27-2011, 09:54 AM | #10 |
03-27-2011, 10:10 AM | #11 |
Thank you =)
03-27-2011, 11:33 AM | #12 |
I was hoping there was some kind of adapter or converter.
03-27-2011, 12:06 PM | #13 |
laying low
There is at least one aftermarket converter available. I have forgotten the name but it runs about $339 if you'd rather not go into the trans. I find BTO sells it.
http://www.bowtieoverdrives.com/cata...m.php?ITEMID=3
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross Last edited by Boog; 03-27-2011 at 12:21 PM. |
03-27-2011, 02:22 PM | #14 |
I have a mechanical tail if you want to exchange,
pm if interested |
