03-27-2011, 12:02 PM | #1 |
4l80/4l85
Anyone running one of these transmissions? If so, was it worth the money and does it fit without beating the floorpans? Any info would help me make my decision on what to do.
"The Ultimate Sleeper" 69' SWB, Holley EFI 525 ci. BB, TH350, 3.73 Eaton posi/Moser axles, 1350 diveshaft, Vintec's 20"x8.5" and 20"x12", OPP windows, CPP rear coilover conversion |
03-27-2011, 01:39 PM | #2 |
Re: 4l80/4l85
Ttt
03-27-2011, 02:17 PM | #3 |
Re: 4l80/4l85
just pulled mine out today i did not have to beat anything for it too fit they just rob ur horse power cause they are so heavy and computer will set u back around 800 unless ur running motor with computer also
03-27-2011, 03:35 PM | #4 |
Re: 4l80/4l85
Do they rob any more hp than a TH400?
03-27-2011, 04:17 PM | #5 |
Re: 4l80/4l85
Yes, good question special-k. Does anyone know the answer to that? What kind of engine are you running weircc? Any other suggestions for an overdrive trans that can stand 800+HP and be reasonably priced? This is the best deal I have found so far. Hot Rod Magazine just put a 4l85 in a 69' Camaro but they paid 7000.00 for theirs from GearStar. Can it be that much better?
http://monstertrans.com/store/produc...mance-2WD.html
03-27-2011, 05:12 PM | #6 |
Re: 4l80/4l85
I have a 4L80 in my 68 crew cab, love it. I used the computer from a 1991 Suburban.
03-27-2011, 05:19 PM | #7 |
Re: 4l80/4l85
extd56 what kind of crossmember did you use for the 4l80? By the way awesome truck.
03-27-2011, 05:33 PM | #8 |
Re: 4l80/4l85
I used mounts from the 1991 Suburban which I believe is the same as a 400 mount. Mine is in a 4x4 so it might make a difference but I took apart a couple of 2x4s and the mount looked like the 400.
03-27-2011, 05:55 PM | #9 |
Re: 4l80/4l85
I have one in my 2wd blazer. It isn't running yet but everything fit fine.
03-27-2011, 06:06 PM | #10 |
Devil's in the Details
Re: 4l80/4l85
I've got one in my Suburban. Since it isn't running quite yet I can only comment on the fit. It clears everything quite easily with the high hump in mine. Had to modify/make my own crossmember, but it wasn't too tough.
'70 K10 Suburban - TBI 454, 4L80E, NP241C, Dana 60 & 44 - The 10+ Year Project Thread Datsun 240Z, 510 2 door and an old Honda motorcycle |
03-27-2011, 09:34 PM | #11 |
Re: 4l80/4l85
i have a big block in my truck i never drove mine with 4l80e just installed because thats what i had but changed my mind didn't feel like dealing with all the computer drama, my truck is a low hump cab it fit great, my stock cross member worked as well. as far as the horse power robbing that's just what several ppl have told me (CANNOT CONFIRM) but it weighs a ton more than the 700r4 i replaced it with that's for sure. i have read that ppl take a 93 computer and strip it down some how to run the 4l80 but could never confirm on how to do it.
03-28-2011, 01:15 AM | #12 |
Re: 4l80/4l85
I have a 4L85E in my 69 with a 502 but haven't driven it yet. It fits great (low hump in my truck). I used my stock crossmember with a th400 trans mount, however, I had to move the crossmember back a bit and drill new bolt holes. I bought the part number from the GM performance parts book (pn 19154550) they call it a "SuperMatic", it's was built to go behind the 720HP 572 (more clutch plates and stuff). It was just over $3000 from the Chevy dealer with conveter (2200 rpm stall) but no computer/wiring harness, dip stick or yoke. It also has no speedo drive gear so you need to buy a electronic to mechanical cable drive or change to digital speedo. Good things are you can tune the trans with a laptop, shift points, shift stiffness, line pressures and if you change tire/wheel size or rear gear ratio you just put the new information in the computer and it recalibrates the speedo.
03-28-2011, 05:12 AM | #13 |
Re: 4l80/4l85
So which years are the best to look out for in the Classifieds, etc?? I've got a line on one locally that's got 12K on a rebuild for $500 with converter, just want to avoid gettin' a model year that might not be the best.
---==Temio Williams Yuba City, CA |
03-28-2011, 05:29 AM | #14 |
Re: 4l80/4l85
97-newer are suppose to be the best
03-28-2011, 08:00 PM | #15 |
Re: 4l80/4l85
Thanks for all the info guys. I see ItsRandy went with the GMPP Supermatic for around 3000.00. As you can see in post #5, Monster Transmission has them for 1777.00. You think this goes back to the old saying "you get what you pay for"? Has anyone dealt with Monster Transmission or heard any testimonials about them. And is a th400 and a th350 mount the same?
03-29-2011, 02:14 AM | #16 | |
Re: 4l80/4l85
03-28-2011, 08:48 PM | #17 |
Re: 4l80/4l85
B&M also sells a computer for $576. It works with 4L80E/4L85E and allows control over several variables without the use of a computer.
http://www.bmracing.com/PRODUCTS/Sim...GM_4L80E_4L85E
'68 C-10 SWB 383 Stroker (Sold 3/2/2013) '87 R2500 LWB 454 TBI converted to Carb |
03-28-2011, 09:16 PM | #18 |
Re: 4l80/4l85
Do you have this unit AusTx68?
03-29-2011, 07:59 PM | #19 |
Re: 4l80/4l85
No, I'm running a 700r4 that is on it's last legs. I'm thinking of going with a 4L80 and found this one when researching computer options.
