03-27-2011, 04:24 PM | #1 |
5/7 kit installed..why is one side lower than other?
front...spindles, shocks and coils
rear..shocks, flip kit, and shackles. truck seems to be higher on one side than other. why would this be? not sure if pics are on level ground. but messured at work and its higher on one side. again, not sure if work ground is level but looks off.., |
03-27-2011, 07:46 PM | #2 |
Double 6's
Re: 5/7 ki6 installed..why is one side lower than other?
Not sure if its the same kinda thing, but I started my "career" with trucks with an S10, and they were notorious for having this problem when static dropped....
Street Glidin! 1966 LWB Custom Cab (sold) 1982 Short Fleet (under the knife) 1998 S10 2wd Fleet 2007 Chevy Silverado Crew 2007 Harley Davidson Street Glide |
03-27-2011, 07:51 PM | #3 |
how are u pulling a measurement? i have always done it from center of wheel up to bottom of fender. that way u will get a better measurement of if u are laying same all the way around. cause measureing from ground up isnt always correct. try to get it on as lvl a ground as u can then measure from center of wheel to botttom of fender. to if u guage from how it looks in pic from rear it does look like the driver side is lower. but if u look on side to side pic then it looks lvl cause look at how the fenders sit on each tire front and rear.
03-27-2011, 08:02 PM | #4 |
Moderator
I had the same problem with my '87 swb. I even swapped front springs side-to-side and it didn't make any difference. It was so bad you could see it across a parking lot. I didn't explore the rear leafs but my next theory was that the driver side was worn down from having the gas tank and driver.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
03-28-2011, 12:10 AM | #5 |
Fabricate till you "puke"
I swapped leafs side for side to level up my Longhorn....crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
03-28-2011, 08:31 AM | #6 |
thanks for replies.
ill try and find some flat ground and then measure from the center to fender. thanks for help, and advice. somedays it looks worse than others. |
03-28-2011, 08:04 PM | #7 |
I think your rear springs are shot. My truck is the same way. I have a pair of what looks to be good ones next to a known mush pair.
The big spring stack weighs a ton. I thought I could use maybe some of the leafs but they are the wrong lenght and arch. When you can feel the difference just by putting my foot on it just add a truck. There's your lean Last edited by 1LowToy; 03-28-2011 at 08:07 PM. |
04-11-2011, 06:58 PM | #8 |
Re: 5/7 kit installed..why is one side lower than other?
i noticed in my tread u commented once and im late but i love the stance of the truck
04-12-2011, 07:31 AM | #9 |
if that was to me and my truck thanks man.
1st time ive heard it since dropping truck |
08-22-2011, 10:30 AM | #10 |
HELP: Just finished a frame off on my 68 C10. Bought a 3/4 lowereing kit and truck was level at all four wheels while cab and bed still off. Drive it once and now driver's side sits 1 inch lower front and rear. Checked springs, seem OK and still in place Any ideas or comments appreciated.
