![]() Join Date: Jan 2002
Shift Indicator
How is the shift indicator lit on a tilt column. Does it use the same fiber optic setup that is on the non tilt column. Mine doesn't look like there is any way for it to be lit.
72 2wd 307/AT/AC/TILT WHEEL 78 JIMMY HIGH SIERRA |
There is a bulb under the PRNDLL. Just take the 2 screws out that hold it on the column and you'll find it underneath.
350 ETec 170 heads, Performer, HEI, Holly TBI, 700r4, 14 bolt rear, F&R lockers, lots of off road improvements. |
The shift indicator is supposed to be light up? I would be happy if it just pointed right. Anyone know how to adjust it?
'72 GMC custom camper 350/350 |
Does your detent lock in when you put the shifter into park?
The only adjustable part of the column that you have is the linkage outside the fire wall. Jim |
Jim, it does lock in. I just replaced the stock linkage with a Kugel linkage setup. But the pointer is still off. When its in Park, it pointing way past the P.
