03-28-2011, 01:03 AM | #1 |
Will Coil Spring Rear Suspension out of 67-72 fit in a 65 Carryall?
I have a 1965 GMC Carryall that currently has leaf springs in it, but was wondering if the rear coil spring suspension out of a 67-72 would "BOLT"in to this rig??
Anybody ever try it?? |
03-28-2011, 01:22 AM | #2 |
60-66 Nut
Re: Will Coil Spring Rear Suspension out of 67-72 fit in a 65 Carryall?
The coil spring suspension should bolt right in that '65 GMC. I believe the trailing arm crossmember should already be in there.
03-28-2011, 09:22 AM | #3 |
Yes and no, the arms will bolt in but you will have to build upper mounts for the coil springs.
--------------------------------------------------------------- Jason. 68’ GMC shortbox https://67-72chevytrucks.com/vboard/...d.php?t=794201 72' 2WD Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=425385 67' LongBox C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=691845 InstaGram ybnorml67 |
