![]() Join Date: Jun 2010
New steering box tips
I am installing a new steering box in my truck. Any tips for a smooth installation? 71 1/2 ton power steering, new box from Advance Discount Auto.
Thanks!
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. |
Re: New steering box tips
Put one bolt in backwards to give you a helping hand while installing. Use that bolt to line the box up on the frame and help hold the box in place while you start the other 3. Once you have the other three started take that bolt out and install it the correct way.
Good idea, thanks. What about lining the new box up? Should I assume it is already in the center position?
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. Last edited by FL71C10; 03-30-2011 at 07:58 PM. |
no more tips? Anyone done this?
Moderator
![]() Join Date: May 2007
i just did this last week. mine was already centered. you will love it! no more slop in your steering.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
So just unbolt the pitman arm and the rag joint, and put them on the new box?
Moderator
yes, you will need a puller to remove the pitman arm. you can buy them at harbor freight for less than $10 or use the loan a tool prograqm at autozone or oreillys.
Did you paint yours before you put it in?
I did not paint mine but it would be a good time to if you so desired. It's really not that hard of a job. It's not surprising there are not many tips.
