Old 03-31-2011, 12:35 AM   #1
jklonowski
jklonowski's Avatar
Water leaking under dash when raining
I have a pretty good water drip under the dash on the driver's side by the fuse box. Trying to see if anyone has had the same problem before I tare apart the dash. Thanks guys for the help.
jklonowski is offline   Reply With Quote
Old 03-31-2011, 12:40 AM   #2
Altec
Getcha Pull
Altec's Avatar
Re: Water leaking under dash when raining
Look inside the cowl. This is a common issue when trash collects in the cowl, and holds moisture. Mine rusted like this, but luck for me it rusted toward the engine bay.
'81 K10 454/SM465
'86 S10 Blazer
'95 H-D Softail
'96 Integra
Altec is offline   Reply With Quote
Old 03-31-2011, 12:49 AM   #3
Hiluxxulih
Hiluxxulih's Avatar
Ditto my 86 has rust holes big enough to pour golf balls into the cab .
Hiluxxulih is offline   Reply With Quote
Old 03-31-2011, 12:59 AM   #4
dmartin1
dmartin1's Avatar
check the windshield seal too,and for rust holes around the area....
note- mine actually had a small crack i the window from a pebble in the corner,and the water seeped through the glass,down behind the dash and to the floor by the fuse box.it had also ran in the crack of the glass to the metal of the cab where the glass sits and started to rust it.good thing i caught it.
1969 Shortbed in progress
1982 short step, few suspension and motor upgrades.getting a 468
1978 Shortbed fleet side bonanza fully loaded
1978 k20 Silverado loaded.currently engine-less
1989 k10 suburban 9" lift
65 nova
And more
dmartin1 is offline   Reply With Quote
Old 03-31-2011, 05:46 AM   #5
justpball
justpball's Avatar
windshield seal on mine leaked too
Fuzzy Dice Club Member
87 Crew SWB
Build for the crew
http://67-72chevytrucks.com/vboard/s...d.php?t=430082
http://www.cardomain.com/ride/3232925
90 burb 2wd
Build Thread For The Burb!
http://67-72chevytrucks.com/vboard/s...d.php?t=383055
justpball is offline   Reply With Quote
Old 03-31-2011, 10:16 AM   #6
blackbeaSSt
im still chasing mine. although i think mine is the heater core on the passenger side
http://67-72chevytrucks.com/vboard/s...d.php?t=423766
blackbeaSSt is offline   Reply With Quote
Old 03-31-2011, 10:25 AM   #7
RandyP
Getting Old; Going Broke
RandyP's Avatar
If it's rainwater/normal water, you have a leak from the outside. If it is sweet smelling like antifreeze, it's your heater core. Pretty darn easy to tell the difference there.
I've been lucky so far and had no leaks on a square, but had one in a early 80's El Camino once that drove me batty. I finally ended up gutting the interior, removing the front sheet metal and going crazy with seam sealer on the firewall after getting a new windshield urethaned in place (vs the butyl tape install).
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
Old 03-31-2011, 10:29 AM   #8
blackbeaSSt
but would the heater core leak with no outside water coming in like rain?
Old 03-31-2011, 11:04 AM   #9
RandyP
RandyP's Avatar
If your heater core is bad and leaking, yes. Are you saying the housing is not sealed up correctly on the firewall and causing a leak, or your heater core is leaking? A leak on the passenger side in the floorboard is generally a good sign your heater core is doing something bad. But you should be able to smell the antifreeze pretty easy, assuming you actually have antifreeze in your cooling system and not just running straight water for some odd reason. You would also notice a drop in your coolant level, depending on the size of the leak.
Old 03-31-2011, 11:28 AM   #10
blackbeaSSt
yeah i got a leak on the passenger side but only when it heavily rains or i am washing it. i haven't noticed the smell of antifreeze and in no way running straight water
Old 03-31-2011, 12:21 PM   #11
TDS-MN
Windshield seal leaks on mine, bottom driver's side. Runs down to the same area as the Original Poster. Leak is much worse if I leave the kick-panel vent open accidentally. So far I have not bothered to try and solve this, though.
TomS.
'98 S-10 Blazer 4dr 4wd - 4.3, AT, stock
'85 K-10 w/ 305, 700r4, np208, and RUST!
SOLD Dec 2014
TDS-MN is offline   Reply With Quote
