Removing Ball Joints / Springs
I went out today to swap front springs on my 66 GMC and I couldnt get the lower ball joint to seperate from the spindle. I took off the kotter pin, the nut and the washer and used a pickle fork to get it off, but it never budged. I even soaked it in PB Blaster.
Is there a trick to getting these off? |
Re: Removing Ball Joints / Springs
Sounds right to me, might check your pickle fork to be sure it is wide enough. Let it soak for a while and maybe a little heat it has worked for me in the past. Be sure to secure your spring!
I just did mine the other day. I replaced my ball joints so I heated up the A arm up with a torch and just pounded the ball joint out with a regular size hammer! One of the ball joints pretty much came apart into many pieces! I heard that it is not a good idea to torch the a-arm as it will increase the size of the ball joint hole but I think we are talkin tiny milli meters. If you intend on reusing the ball joints, I would line up two castle nuts on top of the ball joint threads with just a small amount poking over the top of the threads and start tapping away. Put a jack under the a arm and put about an inch of tension on it will you tap away. It will finally eventually give up!
Kid's Mechanic
You are supporting the lower arm with a jack I hope. I would leave the nut threaded on a bit in case something turned loose before you are ready .
If your taking the bottom joint loose a solid blow with a 2 lb hammer in the circled part of the pic will do it. |
Thanks guys. Ya I have the arm supported. I will try it again to see if I can get it out.
Scrapper 1
Time to invest in a air hammer pickle fork and a air compressor
Oh I have an air hammer, a pickle fork, and a compressor. I just didnt want to use them in case I was doing it wrong.
Do the steering arms have to be removed to get the ball joint off? |
Well, yeah the steering arms are bolted to the spindle. Time to take them off and degrease em and paint em all up nice in purrty anyways!
Kid's Mechanic
if your just swapping springs , NO
