Old 04-04-2011, 07:28 PM   #1
wilberweb
wilberweb's Avatar
Body filler location
Hi, Guys
I have a question on some body filler. I am working on a 55 Chevy
doing a patch panel on the upper cab corner and to fill it in to make the panel match the other corner I needed to fill in the lip that is above the window.
you can see where the spot welds are so I made that area smooth.
is that the way its done or should I just fill in the spot welds and leave the seam like the original cab with the seams visible wasn't sure if this is the way its done. here are some pictures as you can see I covered all the seems in the window frame.
Thanks for your help
-Larry
wilberweb is offline   Reply With Quote
Old 04-04-2011, 11:10 PM   #2
hammerdog57
hammerdog57's Avatar
Re: Body filler location
If you want to fill the seam. I would remove the filler and weld seam solid and then use filler just to be on the safe side. This area expands and contracts alot with the roof sitting out in the sun.
hammerdog57 is offline   Reply With Quote
Old 04-04-2011, 11:21 PM   #3
wilberweb
wilberweb's Avatar
hammerdog57,
I haven't heard of that before.Its a lot of work to take it all back out. have you heard of any one doing it without seam sealant without cracking Or is that just a precaution?
-Larry
