Old 04-04-2011, 08:35 PM   #1
61apachespeed
idle set
what should my idle be in park and it drive?? right now in park its 700 and its drop down to 400 in drive. i have a 327 sbc and 350t. i cant finger out why it does this.
61apachespeed is offline   Reply With Quote
Old 04-04-2011, 10:24 PM   #2
463
463's Avatar
Re: idle set
the tac might be a bit off. i would try another tac first. if they are close the small blocks should idle 800+ and 650 in drive. timing, cams, carb tuning all play into the rpm setings
Trueman
463 is offline   Reply With Quote
Old 04-04-2011, 10:32 PM   #3
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: idle set
Mine idles around 750 to 800 in park, and drops doew to 550 or 600 in drive. 350 with a TH350. But mine has a snotty cam and a stall converter.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 04-04-2011, 10:45 PM   #4
61apachespeed
Re: idle set
i have a hughs 2200 stall converter and a nice cam
Old 04-04-2011, 10:49 PM   #5
cableguy0
Re: idle set
Thats a sure sign of not enough converter. A huge drop from park to drive and lurching at stop lights etc is a dead giveaway that the converter doesnt match the cam. What is the duration @.050 on the cam
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 04-04-2011, 10:57 PM   #6
GASoline71
GASoline71's Avatar
Re: idle set
Doesn't lurch into gear at all... and pulls away smooth at stop lights. 2,800 RPM stall
Lunati 292 Bracketmaster II, 230 @ .050... I might be cheating a bit and have the idle turned down some to make it lope a little more. Just to play around...
Gary
