11-26-2008, 08:49 PM | #1 |
Steering wheel resizing
has anyone ever seen a smaller version of orginial steering wheel possibly aftermarket
12-07-2009, 10:09 PM | #2 |
Re: original steering wheel
I cut one down to 15 inches and took pics of process . Will post pics when I figure out why not posting corrrectly.
68 Short Stepside, 350, quadrajet, 700r4, 3:73 posi, power front discs, HEI, Factory Air, Tilt, Tach, accelerator cable instead of rod, sway bar. 96 Impala SS 97 Monte Carlo |
12-08-2009, 03:39 PM | #3 |
Steering wheel cut and bent to new dia
68 Short Stepside, 350, quadrajet, 700r4, 3:73 posi, power front discs, HEI, Factory Air, Tilt, Tach, accelerator cable instead of rod, sway bar. 96 Impala SS 97 Monte Carlo Last edited by augie; 04-04-2011 at 10:37 PM. |
12-08-2009, 03:56 PM | #4 |
Rim welded together with new spoke locations cut out
68 Short Stepside, 350, quadrajet, 700r4, 3:73 posi, power front discs, HEI, Factory Air, Tilt, Tach, accelerator cable instead of rod, sway bar. 96 Impala SS 97 Monte Carlo Last edited by augie; 04-04-2011 at 10:38 PM. |
12-08-2009, 04:01 PM | #5 |
Had to add extensions to spokes because I cut spokes too short. They should be cut flush with rim.
68 Short Stepside, 350, quadrajet, 700r4, 3:73 posi, power front discs, HEI, Factory Air, Tilt, Tach, accelerator cable instead of rod, sway bar. 96 Impala SS 97 Monte Carlo Last edited by augie; 04-04-2011 at 10:39 PM. |
12-08-2009, 04:10 PM | #6 |
Welding process
68 Short Stepside, 350, quadrajet, 700r4, 3:73 posi, power front discs, HEI, Factory Air, Tilt, Tach, accelerator cable instead of rod, sway bar. 96 Impala SS 97 Monte Carlo Last edited by augie; 04-04-2011 at 10:40 PM. |
12-22-2009, 11:40 PM | #7 |
Registered Chevy Owner
Ok I just saw this thread and I have a question. Do you think that a smaller diameter late model steering wheel would work instead of cutting up the original? I'm thinking a weekend project in in the near future.
Love is fleeting, but Chevy trucks are forever!!!! 1970 Chevy CST C10 long box 350/400 2008 Chevy Silverado short box 4x4 Had; 1951 Chevy short box 307/T5 1988 Chevy shot box 4x4 350/350 1971 Chevy C10 long box 4x4 350/350 1971 Chevy C20 long box 350/350 1971 Chevy C10 long box 350/350 |
12-23-2009, 01:02 PM | #8 |
nickp51chevy: I have used an 80's model Camero wheel that is a direct fit and is 14and 1/4 inches in diameter. I have also used a 90's Chevy truck wheel and it is 15 and 1/2 inches in dia. and does not require modification to fit.
