Old 04-05-2011, 09:49 AM   #1
hayhauler71
hayhauler71's Avatar
Parking brake cable routing
Can someone please throw up a pic of the parking brake cable how it is fastened to the fender well as mine seems to rub on the steering shaft. As always thanks in advance
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 04-05-2011, 12:55 PM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: Parking brake cable routing
someone posted this sometime back:
68gmsee is offline   Reply With Quote
Old 04-05-2011, 01:20 PM   #3
hayhauler71
Still need a pic of the clamps that attach the cable to the inner fenderwell
Fuzzy
Old 04-05-2011, 01:59 PM   #4
68gmsee
Active Member
68gmsee's Avatar
Not sure I know which one you refering to.
Old 04-05-2011, 04:59 PM   #5
hayhauler71
As the cable exits the firewall I believe it is held in place at the inner fender well and possibly the frame before it heads under the cab.
Fuzzy
Old 04-05-2011, 10:12 PM   #6
68gmsee
Active Member
68gmsee's Avatar
What year truck? The one I have hear at the house is a 68 GMC and I'll look at it tomorrow. I suspect they're all the same.
Maybe someone will have a better answer for you.
Old 07-12-2014, 06:17 PM   #7
Beefy Norm
Hi. Not sure if someone has given a good answer yet. I just installed a complete parking brake system on my 69 GMC C10......none of it was there, not even in the drum. I had a lot of similar questions and had to do extensive research on line. The cable that comes out of the firewall has two c clamps that have a tab on them. I can't describe it any better then that, but LMC truck has a good picture of them (2) intheir catalogue. Unless you have aftermarket wheel wells there is a hole drilled into the well just below and slightly to the right of the shaft. The second clamp bolts to the frame.....if I remember right......just below the firewall. I don't remember if LMC sells just the clamps/hold downs but I recommend ot trying to fabricate the two of them. Just save yourself the trouble and buy them. You probably have the advantage of living in the States so having the parts delivered is hassle free. I recently retired to Canada (Its an Obama thing) and LMC isn't too co operative with delivery here to Canada even thought they say they are. Usually, shipping and handeling is about as much as the parts themselves..
Beefy Norm is offline   Reply With Quote
Old 07-12-2014, 06:20 PM   #8
Beefy Norm
OOPS! Good Job, Bob. Except the little square rubber gasket goes into the firewall. This becomes essential during the winter. Otherwise you'll have snow at your feet and in your crotch.
Old 04-07-2011, 06:07 PM   #9
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
Here's 2 pics of my 71. Don't mind the rubber grommet, it needs to be put back in the firewall. Both my 69's also use this same clip bolted to inner fender.
Hope this helps,
Bob
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 04-08-2011, 05:55 PM   #10
hayhauler71
Hope this helps,
Bob
Thanks bobs409 thats what I needed
Fuzzy
