04-08-2011, 01:44 AM | #1 |
Brake fitting sizes
On the flex brake line that comes down to the rear axle and has two female spots. What's the size on that -3an? Also on a mid 70's front caliper. Standard or metric banjo bolt?
Posted via Mobile Device |
04-08-2011, 01:55 AM | #2 |
Re: Brake fitting sizes
Hi bikes&bowties,
The two female ports on the rear axle flex line are SAE 45 deg inverted flare (not AN flare which is 37 deg). They accept 3/16" diameter double flared brake line with 3/8"-24 threaded nuts. GM changed from standard to metric banjo bolts on the calipers sometime in the late 70's (around 78 I think). So mid 70's calipers should be standard ... 7/16"-20 thread if I remember correctly. Last edited by ray_mcavoy; 04-08-2011 at 01:56 AM. |
04-09-2011, 12:47 AM | #3 |
Awesome. Thanks a million
